ipod2car installed, not working
livininvic
Post by livininvic »
I just installed an ipod2car in my '05 vibe... It worked perfectly.... for about 10 minutes, now it is totally intermittent, the audio always plays through, although a bit quiet, but I did find the solution for the volume issue.but mostly the controls do not work at all. once in a while it will change tracks, or start playing when I hit aux, but for the most part it doesn't respond to controls at all. Has anyone had a similar problem and found a solution???
dan326
Re: ipod2car installed, not working (livininvic)
Post by dan326 »
What head unit are you using? You should be switching from radio to ipod by using the band button. Do you have xm? If you do, did you disconnect the tuner? By that I mean did you pull the sub out of the passenger rear quarter and unplug the antenna at that location?
jeffgtx
Re: ipod2car installed, not working (dan326)
Post by jeffgtx »
that happened to me once and i reset my ipod and it never happened again.another thing to check is if you have the AUXPOD DIP switches set correctly?[on my 05, you get to the ipod by pressing AUX, not band]
JeffGTX's Shades Of Gray Pontiac Armada:Cool: 2008 Solstice GXP ConvertibleSly: 2009 Solstice GXP CoupeMaverick: 2009 G8 GXP
GMJAP
Post by GMJAP »
Quote, originally posted by dan326 »What head unit are you using? You should be switching from radio to ipod by using the band button. Do you have xm? If you do, did you disconnect the tuner? By that I mean did you pull the sub out of the passenger rear quarter and unplug the antenna at that location?You can set up the ipod2car to select off either the BAND button or the AUX.
jeffgtx
Re: ipod2car installed, not working (GMJAP)
Post by jeffgtx »
really i never knew that?where did you pick up that tidbit?
GMJAP
Re: ipod2car installed, not working (jeffgtx)
Post by GMJAP »
Quote, originally posted by jeffgtx »really i never knew that?where did you pick up that tidbit?This is the difference between DIP switch settings Config7 and Config8, either of which can be used with the Vibe.(http://peripheralelectronics.c...2.pdf)The ipod2car instructions aren't clear on this, though. The instructions that came with my aux2car were, but now I notice the downloadable ones are pretty much the same as for the ipod2car.I also notice they recommend making sure one's iPod is upgraded with the latest firmware (see above link). So, as an attempt to help the original poster with their question, it may be that if they've had the iPod for a while they may need to upgrade the firmware.
