how do you get the stock speakers out of the doors...
NascarXprt
Post by NascarXprt »
ive tryed drilling and no privail. cant get through one rivet. what size bit do i need for this proccedure.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
Re: how do you get the stock speakers out of the doors... (NascarXprt)
Ugh, it isn't pleasant. I'm not sure what size bit I used, but I do have the pack of rivets I used to reinstall the stock speakers out in the car. I'll get outside tonight and make a note of what size they are. Perhaps that will help...It took quite a bit of drilling for mine, those things are pretty stubborn!
Image Image
Mr. Poopypants
Re: how do you get the stock speakers out of the doors... (ColonelPanic)
Post by Mr. Poopypants »
IIRC, it was a 1/4" bit that I needed to drill out the rivets.
Jahntassa
Post by Jahntassa »
Yeah, use a larger bit. You just need to pop the head off the rivet so it'll fall out the other side. You need a drill with torque, and you need to push on it..
jeffgtx
Re: (Jahntassa)
Post by jeffgtx »
depending on what youa re installing, you dont need to remove teh bracket at all.on the vibe, i removed teh stock speakers and put teh blau's in that bracket as is.in teh vue, i tore the ridge off teh bracket and the speakers fit fine.see my post hereif you wanna try it
JeffGTX's Shades Of Gray Pontiac Armada:Cool: 2008 Solstice GXP ConvertibleSly: 2009 Solstice GXP CoupeMaverick: 2009 G8 GXP
NascarXprt
Re: (jeffgtx)
im installing the DUAL audio 6-1/2" 140watt 3way illuminitieshttp://www.bestbuy.com/site/ol...09826
jeffgtx
Re: (NascarXprt)
Post by jeffgtx »
cant tell for sure from that, but it looks like they dont have an outer lip, you should be able to mount those right in without drilling teh rivets to me.
Jahntassa
Post by Jahntassa »
Keep in mind, you'd be destroying the stock speakers that way...
NascarXprt
now how do you get the speaker out of the bracket?
Jahntassa
Post by Jahntassa »
Destroy it! Basically..you need to rip the cone out..you can use a knife to cut the outer surround of the speaker.. then use whatever you can to break the inner plastic supports on the magnet. And voila! Speaker mounting bracket.
jeffgtx
Re: (Jahntassa)
Post by jeffgtx »
yayaya destroy!!!!what i did was pull the center of the cone out and the rim will want to rip off the outer bracket (its just glued on, no cutting neccesary if you pull slow and steady) then i used a cutter to cut the plastic pieces at the outer rim. see picture from cohocarls post:
