Gauges installed
McVibe
Gauges installed
Post by McVibe »
So I got around to installing my gauges today. I spent 7hours putting them in in 100 degree + weather. I actually enjoyed myself. I'm not sure how but it was fun. But anyway I tried to make my own gauge pod using fiberglass, lets just say it looked like a piece of crap with three eyes and shaped it into a pillar . Yea, so I removed the fiberglass and tommrow I'm going to hopefully cover the pillar in cloth or like foam and cloth. But anyway, I'll get some pics up. Also I have an issue that someone might be able to solve for me. My A/F ratio gauge looks like a cracked-out ADHD boy with sugar. The needle bounces all over the place when the car is just idoling.
2004 Vibe Base Cosmo Racing CAI (Orange) Eurolite Xenon Headlights, foglights, reverse light, Licence Plate Lights and Dome Lights:star: JVC KD-DV5100 Headunit 7" Sharp LCD 2 12" Legacy 500w Subwoofers 400w Legacy Amp Custom Bult Sub box 3 Pillar pod Gauges Painted Engine Cover Jom Billet Aluminum Stubby Anntena
Re: Gauges installed (McVibe)
I do recall seeing one on a GT at some point in time and it did bounce around a bit (but no too much) at idle.Where did you connect the sensor to?
McVibe
Re: Gauges installed (ColonelPanic)
Post by McVibe »
The blue wire coming from the sensor on the exhaust mainfold.
ArcsVibe
Post by ArcsVibe »
Have any pics?
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
Psychobroker
Re: Gauges installed (ArcsVibe)
Post by Psychobroker »
need pics please!
McVibe
Post by McVibe »
I didn't really want to show any yet, it's very ugly because they're only installed and i havn't beautified them yet but here you go. I promise it will look better when I get some nice material on there, I would be cool to get rhino liner, but I don't think it's going to happen.
BlueCrush
Post by BlueCrush »
Cool, nice to see that the gauges worked out.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
McVibe
Re: Gauges installed (BlueCrush)
Post by McVibe »
I also had another issue, I can't get the gauges to dim correctly. I tried to hook them up to the dimmer switch but I thinkl I have them on the wrong wire so any help would be great.Quote, originally posted by BlueCrush »Cool, nice to see that the gauges worked out.Yea, thanks a load
Ponyota
Post by Ponyota »
I'm interested in how you got the trim piece off. Can you post instructions on how you did that please?
Click on signature to view Ponyota on cardomain
zionzr2
Post by zionzr2 »
forgive my ignorence on this question but what does knowing the air/fuel position tell you???
McVibe
Re: Gauges installed (Ponyota)
Post by McVibe »
Ponyota: which trim piece do you mean, I basically had the remove them all to do this.zionzr2: The Air/Fuel Ratio gauge obviously monitors the Air/fuel Mixture present in your exhaust which it then gives you a read out if you are running lean(more air than fuel) Stoich(Good Mixture of fuel and Air) or Rich(More fuel than air).
BlueCrush
Post by BlueCrush »
He's Talking about the A-Pillar piece. How did you remove that piece?
My Fleet:
nismo
Post by nismo »
I would think that it's just clips that hold that piece on if I'm not mistaken.Inder
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
BlueCrush
Re: Gauges installed (TRD4reel)
Post by BlueCrush »
Check here: http://forums.genvibe.com/zerothread?id=17920I attached a link there that will take you to MO for some examples of what they did on the Matrix.
My Fleet:
McVibe
Post by McVibe »
Yea, ragingfish is right, only you do have to pull up on it a little bit once you yank it, as it is stuck in the dash.
