Need to know if the 4 connectors are already there for the VSS security system. I've attached a picture. The connections for the indicator should be near the rear hatch window button, and the other 3 should be on the right dash, near the top. Mike, or anyone else that has had their dash off, do you recall seeing these? I want to add the VSS, it's pretty much the only option I don't have on mine.It's an indicator, a shock sensor (glass breakage), a relay, and a control module. That's the whole thing, but it was never offered as a kit though GM.
