Cool find with the triangle thing. I'm not too surprised about it though. On the base that I work, we have designs carved into the lake bed where the jets fly. Here's a pic of the lakebed I see every time I drive into work. If you look in the top-left corner, you can see a parked jet that you can use for size reference.
Quote, originally posted by Mr. Poopypants »Speaking of JFK, this looks like a little oops on the end of the runway, are those emergency vehicles around that plane?that plane looks like it's in better shape/location than this one
Mase, maybe I'm the only one having this problem but all your files come up as .zip files and the links don't work when I open them. Just wondering. Maybe I am doing something wrong. All the other .kmz files work fine.
Quote, originally posted by damronjr »Mase, maybe I'm the only one having this problem but all your files come up as .zip files and the links don't work when I open them. Just wondering. Maybe I am doing something wrong. All the other .kmz files work fine.You have to unzip them (Winzip is pretty easy to use) to get the KMZ file.
Quote, originally posted by Mr. Poopypants »You have to unzip them (Winzip is pretty easy to use) to get the KMZ file.When I open them it comes up as a .doc file. (removed) is going on here. Maybe it is just my work comp?EDIT: doc.kml is what I get when I save and open it.
Quote, originally posted by damronjr »When I open them it comes up as a .doc file. (removed) is going on here. Maybe it is just my work comp?EDIT: doc.kml is what I get when I save and open it.OK, I have no clue..
thats pretty cool joat... where do you find these nifty things?!i can tell you what google can't do:find chime module for the vibe find the entire series of pacman cartoons on DVD.find teh release date for knight rider the movie....
Quote, originally posted by joatmon »amazing the things you can find on the planetFunny. Did you build it or find it on the internet?Someone has too much time on their hands
We've seen Some of GM's test facilities....how about:Chrysler, Ferrari, Fiat, Ford, Goodyear, Holden, Honda, Nissan, Prototipo, Porsche, Toyota and Volvo:
Actually - several of those companies also use that Cold Weather testing facility in Kapuskasing - GM just happens to be the primary user Gotta love northern Ontario!
2003 Shadow Vibe -- Alloys, Auto, and Allota fun!Vibe #4,873Sadly, traded-in for a 2005 Dodge Grand Caravan
Quote, originally posted by joatmon »I'm just finding them. ok, here is one I did myself. I am miserly with my bandwidth, so I put the kmz file in http://forums.genvibe.com/zerothread?id=17623 in the asylum, so only genvibe members can follow the linklurkers, it is so cool ! Too bad you wont sign up, you just don't know what you are missing
Ok, you guys got me hooked on this Google Earth deal....How about checking out all the fighter jets, B-52's, A-10's, etc. at Nellis AFB near Las Vegas. There's jets all over the grounds at this AFB, not just where I put the thumbtack. Just across the highway from here is also the Las Vegas motor speedway.P.S. I guess I'm not doing it right also. I'm saving the .kmz file, but it's coming up as a zipped doc file when I upload it here.(?)
you create a placemark, if you want you can set the view and edit the placemark, go ito advanced and snapshot current view. Then after you exit edit mode, right click on the placemark and pick save as.Here is an interesting shaped building in California
Would you agree to debris acceptance? 2003 Vibe GTMods installed GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire KitAwaiting install: Energy Suspension Motor Mounts, DC Sports Header
Quote, originally posted by Herb »Perhaps a case of Google going too far?http://moon.google.com/LOL! This good one!! When you up really close and show you cheeses!!
Quote, originally posted by joatmon »ok, here is one I did myself. I am miserly with my bandwidth, so I put the kmz file in http://forums.genvibe.com/zerothread?id=17623 in the asylum, so only genvibe members can follow the linklurkers, it is so cool ! Too bad you wont sign up, you just don't know what you are missing i changed the kmz file in that thread, it now shows something completely different and much cooler. Put a lot of work into it, so check it out if you have GE. And are not a lurker
Quote, originally posted by joatmon »i changed the kmz file in that thread, it now shows something completely different and much cooler. Put a lot of work into it, so check it out if you have GE. And are not a lurker i think its pretty kewl!!
Quote, originally posted by joatmon »i changed the kmz file in that thread, it now shows something completely different and much cooler. Put a lot of work into it, so check it out if you have GE. And are not a lurker Great job!
This one is an image overlay that shows where it is daylight, where it is nght. Kinda hides some of the detail of the regular map, but still interesting.I think the kmz is set to update every ten minutes, but you can manually refresh it faster
I saw that on CNN, and thought cool, I have that program! THey were using that suborbital hop view to switch from on elocation to another.There are some Katrina image overlays available in various threads of the google earth Current Events forum http://bbs.keyhole.com/ubb/pos...vents
Quote, originally posted by joatmon »you create a placemark, if you want you can set the view and edit the placemark, go ito advanced and snapshot current view. Then after you exit edit mode, right click on the placemark and pick save as.Here is an interesting shaped building in California And it's on a Navy base here in SD! I work not far from it! It's on the Navy Amphib Base. Crazy!
I can't get these kmz files to open. What do I use to open them up??
Jen's Vibe:: 2004 two-tone base in Frosty :: Automatic :: Exhaust Tip :: Rear Bumper Protector :: Cargo Nets :: Rear Cargo Mat :: Rear Cargo Cover :: "You just got passed by a wagon " decal :: Red glowing "No Smoking" plug in cigarette lighter ::
KML/KMZ files are data files for Google Earth. Google Earth is a mapping application that you have to download and install on your PC, it's free, about a 10.5 MB download, and is only for windows PCs You can get it from http://earth.google.com/
http://www.gearthblog.com/check out this site for more!(the airport tracking kmz files are cool...3d flight tracking at JFK via google earth is just amazing!)
