The rattle of bass
McVibe
The rattle of bass
Post by McVibe »
So anyway, when I put on my bassy CD in my Vibe, there is the most god-awful rattle coming from the passenger door or maybe the glove box...But at anyrate, It is the most annoying thing ever! Any ideas or people with a similar problem?
2004 Vibe Base Cosmo Racing CAI (Orange) Eurolite Xenon Headlights, foglights, reverse light, Licence Plate Lights and Dome Lights:star: JVC KD-DV5100 Headunit 7" Sharp LCD 2 12" Legacy 500w Subwoofers 400w Legacy Amp Custom Bult Sub box 3 Pillar pod Gauges Painted Engine Cover Jom Billet Aluminum Stubby Anntena
Re: The rattle of bass (McVibe)
Yes.... Back when I had a fully functional stock moon & tunes system, EVERY friggin' door panel rattled! Front more than anything else... Try pushing on the door panel when you've got some heavy bass going on and see if that helps.I know on the driver's side, I had to push my leg against the door panel and keep force on it to keep things from rattling. As far as resolving the rattles permanently, I dunno... But definitely don't use those door pockets for anything other than paper! That really sounds awful when you get some object in there rattling and buzzing about. Right now I just have the two front speakers and tweeters working, and they still rattle the door panels up front. I didn't know if I should try to insulate the door panels or what when I had them off... That may be something to investigate...I certainly feel your pain, this is pretty dang annoying!
Image Image
redlava
Re: The rattle of bass (ColonelPanic)
Post by redlava »
I had that problem in my driverside door. Took it in and it was a loose panel in the door. Probably the same in your case as well.
Re: The rattle of bass (redlava)
I definitely need to rip mine apart again and do some rattle eradication next time I get a chance... Something's definitely loose in there...
Image Image
redlava
Post by redlava »
In your case it is probably the entire door.
