Hi, I new at this and trying out the aux mod that was posted by a fellow member on this http://forums.genvibe.com/zero...age=1 post. I am using a single DPDT switch instead of the relay and toggle switch. My problem is here is how to connect up the Y-cable adapter w/ (one end a mini phone plug) to the switch. On the other end of the cable is 2 main line that has 2 wire in it, one has a red in insulate and the other a white in insulate, both wrap with additional wire and together each set is wrap inside an insulate. Are those none red and white wire ground? I soldered the red and white wire to one of the set on the switch and cutting the remain wiring thinking it is gnd. i tested the sound out but it only work if the switch is activated for the cd, but when i connect the mini phone jack into a mp3 player, I get no sound. Can someone help me out and tell me how to wire the 2nd half up correctly. Thank you.
