Bugatti Veyron 16.4: What a million dollars can buy...
ragingfish
Post by ragingfish »
Technical specs:Curb weight: 4300 lbsSeven gear transmission with dual clutch system, sequential shifting, and a paddle-driven, computer-controlled shifting system that shifts within 0.2 secondsEngine Dimensions (l x w x h): 710 mm x 889 mm x 730 mmEngine: W engine, two V8 banks, arranged at 90°Array: center-mounted, lengthwise in front of rear axleCylinders: 16Piston capacity: 7.993 cmBore x stroke: 86 x 86mmValves: 64, 4 per cylinder, controlled by 4 overhead crankshaftsPower: 736 kw, 1001 hp at 6000 rpmTorque: 1250 Nm (922 ft-lb) at 2200 rpm - 5500 rpmCompression ratio: 9.0Average piston speed: 17.2 m/secSuperchargers: 4 exhaust gas turbo chargersA top speed of 250+ mph (400+ kph)A zero-to-60 time of 3 secondsA zero-to-180 time of 14 secondsA price tag somewhere in the $1 million range.Videos showing the technology and engineering behind the W-16 engine can be found here: * Go to http://www.bugatti-cars.de * Choose "English". * Along the top, click on "Models" * Choose "Veyron 16.4" * Choose "Engineering" * Choose "Engine" * Along the bottom, choose "Legends from 1001 HP" * Click on video segments 1 through 7 in sequence. You may have to click the play button (small arrow) to get them to play initially.
2009 PONTIAC G8
nismo
Re: Bugatti Veyron 16.4: What a million dollars can buy... (ragingfish)
Post by nismo »
That thing weighs a lot! But the power makes up for it. That's nice. But I prolly won't have that kind of money anytime soon.Inder
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
I wonder how many gallons per mile that thing gets?
Image Image
soldierguy
Post by soldierguy »
Being an engine geek, I'm fascinated with that engine. The fact that I'm an engine geek is also why I ordered the Vibe GT...the more I read about the 2zz engine the more I knew I wanted one.Anyway, that engine has as its root the VW VR6 engine, the one that was in my 96 Jetta GLX. VW wanted a 6-cylinder that would fit in a space designed for 4 cylinders. A conventional 60 or 90 degree V was too wide, and an inline 6 would have been too long. So they made a 15 degree V between the cylinder banks and capped it with a single head casting. Because it has one head covering 2 banks of cylinders, the tops of the pistons are angled to keep them square with the head and keep compression consistent at 10:1 all around. Like an inline engine, the air comes in on one side of the engine, and the exhaust exits on the other side, making for an incredibly complex head casting. And due to space limitations, the exhaust ports are different shapes...they alternate between roughly square and kinda oblong. Looks odd, but it works. The end result was 172-177 hp (depending on if it was installed in a Corrado, Passat, or Jetta), and 173-177 lb-ft of torque. And the sound is amazing on those...little bit of a lope at idle, turning into a brassy moan in the midrange, and a beautiful deep throaty scream at the high end. I bought the Jetta simply because of the engine. Later versions fattened the torque curve, and the latest models are either 2.8L and 200 hp with the new 4-valve head, or 3.2L and 240hp in the Golf R32 or Audi TT 3.2. And for non-north America use, there were also 4 and 5 cylinder variations.The great thing about that engine is its flexibility...the W8 in the Passat W8 is just 2 VR4 engines joined at the crank, and the 16 cylinder model is 4 VR4 engines. I know VW messed with a W12 version (2 VR6 engines) but don't know if it is in production anywhere...might be the engine that's in the VW Paheton 12 cylinder, but I'm not positive.The Bugatti W16 is a great engine...has its roots in a mass produced sedan engine, but it obviously delivers the goods with 1001 hp.
soldierguyCurrent Vehicles:2005 Jeep Grand Cherokee Limited: HEMI, Quadra-Drive II, rear-seat DVD entertainment, 6-disc in-dash Boston Acoustics sound system...I LOVE THIS VEHICLE!!! But I also still like hanging here at GenVibe!2000 Dodge Dakota 4X4 Club Cab 4.7L V8 - SOLDhttp://www.cardomain.com/id/soldierguy
wicked1981
Post by wicked1981 »
This car is AWESOME!!!!
POLO
Bugatti Veyron 16·4(56k warning)
Post by POLO »
(Introducing the impressive new Bugatti Veyron 1001 hpGeneral Info Price: $800,000 Miles Per Gallon: --- mpg Curb Weight: --- lbs Layout: Mid-Engine/AWD Transmission: 7-Speed Sequential Engine Type: Quad-Turbo W16 Displacement: 7993 cc Horsepower: 1001 bhp @ 6000 rpm Torque: 922 lb-ft @ 3500 rpm Redline: --- rpm Performance 0-60 mph: 3 sec 0-100 mph: --- sec Quarter Mile: --- sec @ 112 mph Skidpad: --- Top Speed: 252 mph Braking, 60-0 mph: --- ft Slalom Speed: --- mph
POLO
Re: Bugatti Veyron 16·4(56k warning) (POLO)
Post by POLO »
Sorry i can't resist to put other picture. The past and the present.And more.
BlueCrush
Post by BlueCrush »
Holy Crap! I need to go buy a lottery ticket.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
bud_one
Post by bud_one »
One gorgeous automobile....
ScottS
Post by ScottS »
That is the coolest car ever built. What's even cooler is how you get it to hit its top speed.http://www.autoexpress.co.uk/n....html
04 GT Satellite MonotoneWith Stuff
Mr. Poopypants
Post by Mr. Poopypants »
I notice the MPG is blank. Is that because it's actually rated in gallons per mile?
russ257
Re: Bugatti Veyron 16·4(56k warning) (Mr. Poopypants)
Post by russ257 »
that is a hot car. i think the top speed key is a lil stupid since since it only gets you 15.5 mph more then without.while looking around i discoverd this http://www.koenigsegg.com
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
Mavrik
Re: Bugatti Veyron 16·4(56k warning) (russ257)
Post by Mavrik »
Forget the STI... I know what I want now!
ZubenElGenubi
Re: Bugatti Veyron 16·4(56k warning) (Mavrik)
Post by ZubenElGenubi »
That is one fine piece of artwork...and yet, somehow that front grill looks familiar:
bud_one
Re: Bugatti Veyron 16·4(56k warning) (ScottS)
Post by bud_one »
the article says "tyre pressure" - is that right?tyre.....?
russ257
Re: Bugatti Veyron 16·4(56k warning) (bud_one)
Post by russ257 »
if you are from england
~MRVIBE2006~
Fastest (and most expensive) car on the planet!
Post by ~MRVIBE2006~ »
If anyone hasn't heard of the Bugatti Veyron, then they are missing out. A car that produces just over 1,000 HP, has 10 radiators, and can go from 0-60 in 2.5 seconds with a top speed of 253 MPH. Yes, I said 253 MPH! The list price, according to the man in the video, is approximately 850.000 pounds or $1,697,624.31 at current exchange rates. This car is AMAZING! Also, when you go to their website http://www.bugatti-configurato....html , the only options that you have when building are the colors of the interion/exterior, stone chip guards and 3 different types of seats.I call this, my LOTTERY CAR. As that I would only beable to afford it AFTER I won the lottery!Enjoy!Heres the link to the video. http://www.metacafe.com/watch/...yron/
2006 ABYSS VIBE: 20% TINT ALL AROUND FRONT & REAR SPLASH GUARDS MAGNAFLOW CAT-BACK EXHAUST GOODYEAR EAGLE GT (235/45/17) WITH TC WHEELS (SUMMER) DUNLOP WINTER SPORT M3 (215/55/16) ON STOCK ALLOYS (WINTER) AUTO VENTSHADE WINDOW VENTS PLUS SUNROOF VENT K/N AIR FILTER,OTHER DRESS-UP GOODIES...
Sublimewind
Post by Sublimewind »
Yeah, that's about the sickest thing on the roads anymore... I saw the Youtube spot on it where a guy drove it up past 210mph... It's just crazy... at over 200 the tires will last like 500mi and it'll gulp a tank of gas in 30min or something like that... It has 2 keys, one gives you ~500hp the other gives the 1000hp to you... Crazy
Sublimewind
Whelan
Re: (Sublimewind)
Post by Whelan »
This car has been out for a little while now. A lot of people critique it for being ugly. But it's not designed to look like an S500, it's built for speed. When you put in the second key for speed mode, the huge spoiler pops up in back and the car actually lowers itself and has a vacuum system that basically sucks it to the road for traction. Complete with a W16 Quad-turbo setup. They took two W8 engines and basically put them together. P.S. - the W is a volkswagen design.
2012 GLI Autobahn 6MT
~MRVIBE2006~
Re: (Whelan)
I know it's been out for a little while. But it's nice to stir up interest about such a UBER car. This car is THE speed freaks fantasy car. And just imagine, the wing on this car actually serves a purpose! Unlike all those posers that drill a few holes in their trunk lid and the bolt on some god-awful ugly wing-like thing in there that there is no way that it could help them! Oh well, it is their money to waste! And about wings,I do like the top spoiler on the Vibe. It actually fits it well and looks pretty good. I hope to get one here soon, if possible.
Vibr8tr
Re: (~MRVIBE2006~)
Post by Vibr8tr »
I think this car looks awsome. I have always liked it from the moment I first read about it. And even though that is the list price, they are usually ALOt more expensive. Just like the Ford GT, it lists on the site at only like $150,000... but if you go to a dealer to buy it you end up paying like $300K.
MSN: jjbova@hotmail.com - Yahoo: jjbova - Myspace: http://www.myspace.com/jjbovaSee My Vibe at Cardomain.com
~MRVIBE2006~
Re: (Vibr8tr)
I agree. Even with the list price at $1.7 million, you probably cant touch one for under $2 million.
Whelan
Re: (~MRVIBE2006~)
Post by Whelan »
That spoiler creates 770lbs of downforce. Imagine that on the back of your hatch, ouch. Not to mention when braking from 250-0 it takes only 10 seconds! The spoiler tilts and creates .5g of deceleration. The driver can let go of the wheel and the car will still brake in a straight line!Oh and in order to go to Top Speed Mode, the car needs to be stopped, the key inserted, and the car does a check on itself and the driver apparently to make sure all is good to go fast!go to wikipedia, it's a sick article!
ajflan
Re: (Whelan)
Post by ajflan »
Actually, in order to reach its top speed, the spoiler is lowered, to become more streamlined.
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
redlava
Re: (ajflan)
Post by redlava »
A million dollars will also buy you about 4,000 of these.
tangerine
Post by tangerine »
Car is Fugly.
04 Fusion Orange Base Vibe auto Now no longer with us thanks to ignorant drivers...
~MRVIBE2006~
Re: (tangerine)
How did MY topic get hi-jacked and moved? I thought it was in the right place to be posted. I just don't understand and don't like it.
millster
Re: (~MRVIBE2006~)
Post by millster »
Because there were already TWO topics on the same thing that had been posted about a year prior to yours.It wasn't "hi-jacked" I just merged the three together. You received an IM stating that as well.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
kostby
Post by kostby »
My favorite article about the Veyron was in Automobile Magazine --> http://www.automobilemag.com/r...gatti_ ... orida.html
Pyro-Andrew
Post by Pyro-Andrew »
Definetly worth it! that car is a thing of beauty!!!
Have: 2006 Pontiac Torrent. Perferred Package. Sun & Sounds Package. Blue Streak Color. Sirius Radio.
