new brake noise
Thewhite
new brake noise
Post by Thewhite »
at 70 000 km, I was starting hearing the typical "change me!" noise from my front brakes. I replace them with OEM pieces, but now I still hear the noise on medium and hard breaking. Any comments?
'03 Vibe StandardFast Wheel Talon 17x7 Toyo Proxes T1-S 225/45Magnaflow Cat backDevelop's Strut Tower Brace
Psychobroker
Re: new brake noise (Thewhite)
Post by Psychobroker »
They could just be "seating"...did you install semi-metallic pads? If so, they'll always squeel a little bit. I have EBC Greenstuffs, and they squeek a under light braking
Mr. Poopypants
Post by Mr. Poopypants »
Quote, originally posted by Thewhite »at 70 000 km, I was starting hearing the typical "change me!" noise from my front brakes. I replace them with OEM pieces, but now I still hear the noise on medium and hard breaking. Any comments?Did you get your rotors cut when you replaced the brakes? or Did you clean the calipers and rotor?
Thewhite
Re: new brake noise (Mr. Poopypants)
Post by Thewhite »
I didn't install the new brakes myself. I went to Goodwrench, asked them to change oil and install new brakes in front. they asked if I wanted semi-metallic, and I said no cause I don't want the noise coming with it. so all I know is that they put Toyota's pieces and they brought my galipers and dics somewhere to do something with them and brought them back to complete the install. I gonna have to repaint the galipers SO still have the noise with medium and hard braking...
