A cool math exercise...can you crack the equation?
Kari
Post by Kari »
First...1. Grab a calculator. (you won't be able to do this one in your head)2. Key in the first three digits of your phone number (NOT the area code)3. Multiply by 804. Add 15. Multiply by 2506. Add the last 4 digits of your phone number7. Add the last 4 digits of your phone number again.8. Subtract 2509. Divide number by 2Do you recognize the answer?Second...can you figure out why it works?
GenVibe Global Moderator
ragingfish
Re: A cool math exercise...can you crack the equation? (Kari)
Post by ragingfish »
2009 PONTIAC G8
Re: A cool math exercise...can you crack the equation? (ragingfish)
Well damn it, it was new to us! (removed)
zionzr2
Post by zionzr2 »
If you are supposed to get your phone number as a final number it did not work for meEDIT: Never mind i c what i did wrong hehehe
Kari
Re: (zionzr2)
Post by Kari »
Quote, originally posted by zionzr2 »If you are supposed to get your phone number as a final number it did not work for meYeah the first time I did it, I got like 212millionsomething... Apparently I have trouble operating the calculator...
zionzr2
Re: (Kari)
Post by zionzr2 »
my mistake was i was adding the last 4 individualy instead of as 1 number
