Underbody Neon's
MoonDogg
Underbody Neon's
Post by MoonDogg »
I am installing underbody Neon's and have got all the wires ran and the front neon mounted and know how I am mounting the sides (just waiting to put it on lift at friends shop) but I am still tring to figure out were to mount the back one. I tried putting it behind the bumber mounts, but that did not work.. any sugestions or picutes would be greatly apriciated. Thanks in advanced.
2004 Vibe GT Fusion OrangeOptions: M&T, Monotone Paint, 35% TintMods: Kenwood Excelon KDC-X659 HU, Orion CS200.4 amp, Kicker Comp VR 10" sub, Megan Racing STB, Injen CAI, Magnaflow Cat-Back, brass shifter bushing, underbody orange neon's.
Merzbow
Re: Underbody Neon's (MoonDogg)
Post by Merzbow »
I attatched my rear ones on the rear cross bar of the chassis. The cross bar is curved though so it kept breaking the screws. So basically I looked like a moron driving around with one side of my neon tube peeking out. So to solve this problem I used two "L" brackets about 3"x3" or so and atatched them to the chassis and then attatched the tube to the brackets. it helps absorb more shock from the bumps and also brings it lower to the ground. Since the rear of the chassis is high off the ground, if you just bolt it to the chassis it wont be as bright If you need me to take pictures of the installation point or something let me know I just got a shiny new camera for xmas
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
MoonDogg
Re: Underbody Neon's (Merzbow)
Post by MoonDogg »
Yes yes yes.. pictures would be wonderfull!!! how they say that.. a picture is worth 1000 words...
scherry2
Post by scherry2 »
I just made 3 peices of 1x2 inch metal plates screwed them to the frame and screwed the neon brackets to them. same Idea as merzbow just done a little different.
Jahntassa
Post by Jahntassa »
I think I remember using cable ties to secure the back one...i'll have to take a look and see exactly what I did.
MoonDogg
Post by MoonDogg »
Anyone with pictures? Would be greatly helpfull... and when I am done I will get pictures and post them here...
Merzbow
Post by Merzbow »
Once again, excuse the salty/slushy car, too cold to wash now.
Merzbow
Post by Merzbow »
#2
Merzbow
Post by Merzbow »
#3I can try to get better pics tomorow when it's light out. I think if I were to use just a flat bracket instead of an L bracket it would be even brighter on the ground since the L bracket raises the tube about 2 inches higher. I was more concerned with the tube getting mounted on a flat surface instead of the curved chassis that I didn't think about how close I wanted the tube to the ground.
MoonDogg
Post by MoonDogg »
Thanks a bunch... that definatly points me in the right direction... luckily I work in a machine shop.. brackets should be easy to make
Merzbow
Post by Merzbow »
That's a good idea, I have metal shop class right now! lol, I was thinking of making a new aluminum battery tie-down.
MoonDogg
Post by MoonDogg »
Thanks for all the help.. I got them on last night.. and they look good.. I will get some night pics tonight and post them later on...
MoonDogg
Post by MoonDogg »
Well I finaly got the pics of how I got the back one on... I will try and take night pictures tonight... here are the pictures [IMG]http://www.billetcnc.com/vibegt/neon's/1.jpg[/IMG] [IMG]http://www.billetcnc.com/vibegt/neon's/2.jpg[/IMG] [IMG]http://www.billetcnc.com/vibegt/neon's/3.jpg[/IMG]
MoonDogg
Post by MoonDogg »
Looks like something wrong with html tags... copy and paste links and should get pics...
Merzbow
Post by Merzbow »
I'm guesing thats the back tube! I can't wait to see the night shots! I was debating on putting mine on today since its like 40 degrees out!!! Pathedic how 40 degrees feels warm now. I think I'm gonna wait til March though I don't want to get any ice on it. I'lll be installing the transformer and maybe the front and rear tubes today though. The front and rear wont work until I get the sides in but that's fine. Just less work to do and more time to enjoy it when March rolls around.
MoonDogg
Post by MoonDogg »
Well.. over a month later.. I got night shots... I am only going to post the good ones Tell me what you think...
MoonDogg
Post by MoonDogg »
Next...
MoonDogg
Post by MoonDogg »
MoonDogg
Post by MoonDogg »
no flash...
Merzbow
Post by Merzbow »
that looks wonderful on the fusion! Do you get alot of stares?
MoonDogg
Post by MoonDogg »
yeah... an't got pulled over yet either... "knocks on wood"
