Im not an electrician, and I hate tearing things apart because I usually dont put them back together. I have a 2004 Vibe, with single CD and Moons and Tunes. What is the simplest way of enabling the head unit to listen to my XM receiver. I have followed this site for awhile, and alot of great ways of eliminating the FM modulator. In SIMPLE terms what do I need to buy to hook directly to the head unit?I bought an Audiovox XCS9 Combo pack, came with everything needed for the car for only $97.00 at Circuit City. Will get pictures after installing. Thank you in advance for any help anyone can give me.
God, grant me the serenity to accept the things I can not change,the courage to change the things I can, and the wisdom to know the difference.
If you have the BAND button somewhere on your radio, you should be able to get this: http://www.autotoys.com/x/cata....html That's the aux-in that plugs in behind the radio, then you'll need an 1/8" (headphone) to RCA cable you can get from radio shack. Getting to the radio is pretty easy.Ragingfish is right, the -easiest- way is to use FM Modulation. If you're willing to spend a little bit of money, and a little bit of time, the AUX in method is your best bet for clarity.
I have no quamms about pulling the radio and buying something that will let me hook it up directly to the radio. I do have the Band button and the CD/AUX button. Which button would the AUX Box enable? and have all the bugs been worked out of these things yet?
I think the BAND...I don't have one, but there are other threads in the past few days that cover some stuff.
