Hi Jeff, welcome to genvibepotential buyers have to decide between Matrix vs Vibe, and also between the base model vs. GT/XRS. You have both. What do you think of the differences?my 2003 base vibe has a throttle cable, I'm not sure how I feel about "drive by wire" as far as pollution goes,
http://www.fueleconomy.gov has a way you can compare two vehicles side by side, and when I compared the two, the 04 XRS put out a little bit more greenhouse gasses (probably due to to the lower rated mpgs) but the 05 base auto Vibe scored significantly better on their EPA pollution score, the XRS at 1 out of 10, the Vibe at 6 out of 10. Not sure exactly what those scores really mean, but on the surface it indicates that the base is a lot cleaner than the GT/XRS. It may not be as dramtatic a difference though, as the cars run on different fuel grades, and might be in different classes , making direct comparison more difficult, I don't know.
