warm up period
blondie
warm up period
Post by blondie »
Is anyone having problems with the Vibe staying in second gear for a long time before it shifts when it is cold?
nismo
Re: warm up period (blondie)
Post by nismo »
Never had that problem. I would suggest waiting for your car to warm up before you drive it.Inder
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
ragingfish
Post by ragingfish »
Everything runs more harshly when it's cold. My engine is louder, my tranny is more notchy, etc. As said, give the engine a few minutes to warm up if you can, otherwise, sounds normal
2009 PONTIAC G8
greenfire
Post by greenfire »
It should be staying in 3rd gear until the car warms up. Once the car gets close to operating temperature it will shift into fourth. The transmission is programed that way so the car warms up properly and you will not harm anything by driving it cold.
2005 Flint Mica Scion tCTRD exhaustFormer Car: 2003 Matrix xr4wd
SirMoosealot13
Post by SirMoosealot13 »
the vibes computer is set to have the engine rev at a lower rpm until it warms to the proper temp, what your experiencing is a safety mechinism in place to protect from abnormal engine stress....just give it a few to warm up....or, if youre in a really cold climate, i would recommend getting the block heater, for about 50$ installed its a decent purchase.
nismo
Re: warm up period (SirMoosealot13)
Post by nismo »
I wish I had that heater . It come in handy so well right now.
zionzr2
Post by zionzr2 »
I havent noticed anything weird in second, but occassionaly it will hesitate going from 3rd to 4th(overdrive)
blondie
Post by blondie »
I've talked to other Vibe owners at work and they don't have this problem. I also drove a new one at 3 degrees and it shifted right through the gears. Is it possible for some to do it and not others?
nismo
Post by nismo »
Did you buy your Vibe new or used? If used, then the ECU probably got used to the way the previous owner used to drive the car. If it's new, try to discount the battery for like 10 minutes and hook it back up and the ECU should be reset. Once you do this, the car will gradually start learning the way you drive.
