Well I tried installing a short ram intake, but I didn't have the necessary hardware to finish the job (I needed 2 longer screws for that sensor thingy cuz I just got the intake manifold from a friend). Anyways, I installed the factory intake back in and now the CEL (check engine light) came on and my Vibe is not idling like it used to (Idles between 1200-1400 back and forth). I checked the air lines and didn't notice anything wrong. Any suggestions?
2004 Neptune Pontiac VibeAutomaticMoons & tunes packageTinted windows
mine worked fine also, used them.but your idle issue, may be a vac prob possibly or as mentioned a MAF problem. However the usual symptoms of a bad MAF is idles fine but you can't rev past 2800rpm.
Quote, originally posted by Mavrik »mine worked fine also, used them.but your idle issue, may be a vac prob possibly or as mentioned a MAF problem. However the usual symptoms of a bad MAF is idles fine but you can't rev past 2800rpm. I had that problem when I first installed my CAI, make sure you put the hoses back in the proper spots if not it will rev back and forth like you said. Good Luck!
04 GT Satellite Monotone17'' Fittipaldi Fins on Falkin Azenis ST115'sMoon and Tunes/Sirius Satallite RadioInjen CAI/Magnaflow Cat-back Exhaust GM Top Spoiler/Debaged SilverStar Fogs "I wasn’t born rich, I’m good looking instead"
Well I took it to the shop and it took them awhile to figure it out. They replaced the intake gasket and now it works fine. Hopefully it will stay like that!
