Missing 12-volt Outlet in Floor Console
Stealth Wgn
Post by Stealth Wgn »
05 with missing 12-volt Outlet in Floor Console, just a hole behine the flip-up cover, is this a common occurence? Mistake or Cost Savings? Called dealer, they said they would look at it at the first oil change. Called GM, 800-GM-DRIVE and still awaiting a reply after one week. It is still indicated in both the sales brochure and owner's manual.
tnpartsguy
Re: Missing 12-volt Outlet in Floor Console (Stealth Wgn)
Post by tnpartsguy »
It probablly got pushed through....the service manager at our Pontiac Dealer told me to make sure mine was tight, that they have had to reseat a lot of them.
simon
Post by simon »
They whacked the console power outlet off the list of standard equipment for 2005. Do check this thread: http://forums.genvibe.com/zerothread?id=12127You'll have to get it added one way or another... Looks like the wiring is still there, so you would just need the socket.
kostby
Post by kostby »
Welcome to the Encyclopedia of Vibe!Of course I'm sure you've noticed that the GM beancounters also removed the black crossbars from the roof rack on the '05's
