Cleaning fuel injectors
vibechick03
Post by vibechick03 »
The place that changes my oil has told me twice now that I need to have my injectors cleaned. They told me it is suppose to be done every 12,000 miles. Ok, so the car is driving absolutely perfecto!! Are they wanting my $70?? Do I need to have this done?? I have put cleaner in the fuel tank, and tried the other option of gunning it a few times on the highway to get goop off of the injectors (but yet I always do that!!) So.....help???
'03 Base VibeSatellite MonotoneMoons and tunesKeyless entry / electric everythingTinted windows and pin stripe (ordered from someone else)Metallic white overlays, Pearl white rims paintedNext: Magnaflow exhaust & Injen CAI Xenon blue head-light bulbs and blinkers
damronjr
Re: Cleaning fuel injectors (vibechick03)
Post by damronjr »
Off topic, but just noticed... North Dallas??? I am originally from Allen TX but am in San Diego in the Navy right now. Just curious. As for the injector cleaning, if it's not listed in the owner's manual as a required maintenance then I would think they are just trying to get your $$. Check the O.M. and see what it says under 12k check-up. If it's not there, I wouldn't do it.
soldierguy
Post by soldierguy »
Cleaning injectors is generally not necessary. And if they ever do need it, a bottle of Techron in the tank will take care of it. I throw in a bottle about every 5-10K miles just to make sure everything is clean. Probably unnecessary, but I'm knida (removed) retentive about vehicle maintenance.$70 for an injector cleaning is insane when a $5 bottle of Techron will do the same thing. Or if you're happy with whatever brand of fuel cleaner you're using, stick with that.
soldierguyCurrent Vehicles:2005 Jeep Grand Cherokee Limited: HEMI, Quadra-Drive II, rear-seat DVD entertainment, 6-disc in-dash Boston Acoustics sound system...I LOVE THIS VEHICLE!!! But I also still like hanging here at GenVibe!2000 Dodge Dakota 4X4 Club Cab 4.7L V8 - SOLDhttp://www.cardomain.com/id/soldierguy
Mavrik
Re: Cleaning fuel injectors (silverawd26)
Post by Mavrik »
Its called preventative maintanence, why wait for it to break when you can service it now and not have it break later? Injector flushes are not a scam or something to wait until you get poor milage to do, here in canada its recommended every 25,000km. However ranges at about $70 CAD.
vibechick03
Re: Cleaning fuel injectors (damronjr)
Off topic AGAIN, I'm in Lewisville....now where it is?
vibechick03
I saw the topic and thats why I'm asking again..... The guy told me if you use a $5 fuel additive, you get a $5 cleaning, hence my car is at 33,000 miles......do it or not???
vibechick03
Coolant flushed huh.....you got me there!!! Why does coolant cause a problem, never heard of that one.....did i miss that discussion??? lol
damronjr
Post by damronjr »
I was saying I was off topic for asking where you where, not you for asking the question!
Re: Cleaning fuel injectors (Mavrik)
I can tell quite a difference after I recently had the injector cleaning/engine decarbon thing done.. Although I was hoping my ticking engine was due to depostis or whatnot, so that was really the main reason I had it done. In the end, the ticking went away until it got cold and now it's back, so that didn't fix it unfortunately. But getting the service done was a good idea, it really made the car run much smoother and has just a bit more pep.Still not exactly sure what exactly it was they did under this service... Mavrik, can you give us a bit of info about what they do for this service? They just called it an "emissions service" on my paperwork... I'm assuming they run a solution through the fuel line to clean the injectors, and in turn makes its way into the engine to help burn up deposits... ? I don't know for sure...My dealer recommends it ever 30K, which I do believe I will keep having it done at that interval. They said GM recommends it every 15K? Regardless, this service definitely can't hurt... May be worth it in the long run. And a bottle of Techron every now and then is a good thing too.
Image Image
ToolGuy
Re: Cleaning fuel injectors (soldierguy)
Post by ToolGuy »
Quote, originally posted by soldierguy »Cleaning injectors is generally not necessary. And if they ever do need it, a bottle of Techron in the tank will take care of it. I throw in a bottle about every 5-10K miles just to make sure everything is clean. Probably unnecessary, but I'm knida (removed) retentive about vehicle maintenance.$70 for an injector cleaning is insane when a $5 bottle of Techron will do the same thing. Or if you're happy with whatever brand of fuel cleaner you're using, stick with that.What he said and you should be fine! Techron works!!!!!! Use it, not a cheaper brand, GM recommended too.
Altus
Re: Cleaning fuel injectors (MiVibe-ToolGuy)
Post by Altus »
I've been told that Techron is pretty good stuff -- too bad we here in Canada can never find the good stuff! If someone knows where to find Techron in Ontario, let me know.And the absolute BEST engine product I've found has been Seafoam.This stuff is liquid mechanic in a can, I swear.....http://www.seafoamsales.com/motorTuneUp.htmMainly motorcycle experience, but I've used it as carb cleaner, fuel system cleaner, oil cleaner, and fuel stabilizer and it's brilliant at all of 'em.Mostly have to get it from the US, but I've been hearing there's been a limited supply for sale around Ontario recently.I'm also told it does wonders for fuel-injection -- so as soon as I can get my grubby little hands on a few more cans I'm going to be giving the Vibe a shot of it too
2003 Shadow Vibe -- Alloys, Auto, and Allota fun!Vibe #4,873Sadly, traded-in for a 2005 Dodge Grand Caravan
