Loose storage tub under the shifter.
Thxalot
Post by Thxalot »
Hi Folks,The little tub under my shifter is always popping open. Has anyone found a way to keep that sucker closed?I had a 2004 Matrix XR rental a few weeks ago, and that one's little tub would not close at all! I guess the NUMMI guys haven't figured out how to keep these tight either.Thanks for any advice,-Burt
Vibe GT: 225x45x17 Michelin PS2s on OZ Racing Rims | Eibach/TRD Springs | Progress Antiroll Bar | GMD Exhaust (pulled due to freeway drone) | G2 Painted Calipers'02 Audi A4 Avant Quattro | 3.0L | 6-speed | bone-stock'90 ZR-1 375 HP | 375 ft-lb | 4.6s 0-60 | 176 MPH
ragingfish
Re: Loose storage tub under the shifter. (Thxalot)
Post by ragingfish »
It's an inherent quality of molded plastics. No two are ever the same, and they do wear down over time (meaning they don't hold as tightly).Searching for "storage" I found:http://forums.genvibe.com/zerothread?id=777
2009 PONTIAC G8
I didn't have any problems with mine until the dealer tore up the shifter console and I had them replace it. After that, it was always opening on its own.Definitely look into what the other thread shows. Quite an annoying problem, but it's fixed very easily. For mine, I simply added two pieces of electrical tape to each leg that is on the bottom of the compartment. Hasn't opened since, unless I make it open!
Nick1556
Post by Nick1556 »
That's odd. I have a problem of just trying to get it open.
Moons and TunesXM RadioRed neons under the seats and inside the glove boxRed LEDs inside the vent ductsBlue neons under the carRF 900 watt ampSony Xplod 12 subwooferXeon blue headlights, foglights, and backup lights
04shadowvibe
Post by 04shadowvibe »
I have this same problem on my 04 Vibe, I never use the compartment, but it keeps falling open whenever I hit a bump or put it in park. Is there a fix for this from GM?
2006 Vibe AWD, Platinum/Graphite, Sun and Sound Package - Sisters
2007 Vibe FWD, Neptune/Graphite, Base
PAST - 04 Shadow Base, Moons and Tunes, Monotone, Traded at 23K for the 06 AWD.
vivianyorke
Post by vivianyorke »
I complained about this rinky-dink latch 2 years ago! My 2003 Vibe had this problem from day 1. I wedge a black, fold-back paper clip under mine, but it doesn't help a lot -- it just keeps it from popping open completely. I bought my car in June 2002.Joie de VivKingston, OntarioSalsa 2-tone
Cheers!Vivian Yorke, Kingston, Ontario, CanadaSalsa Vibe, 5-speed, "Sport" and "Power" packages Vrooooom, Vrooooom
AJ_'04 Vibe
Post by AJ_'04 Vibe »
A folded up wrapper from a Snickers candy bar worked for me.
'04 VibeSalsa4 spd AutoNo mods yet, but just wait!!
POLO
Post by POLO »
Hy,Mine's is ok,but seem's fragile.But,i thing i have the solution at: http://cgi.ebay.com/ebaymotors...sting
Mavrik
Re: Loose storage tub under the shifter. (POLO)
Post by Mavrik »
well you can go to GM and get the updated part or simply fix up your own by glueing two small pieces on the bottom by each plastic hinge... one per side so that it causes the storage door to sit up higher therefore allowing the small latch to sit more deeply into its hole and the door will stay closed. Most 04 Vibes, mine anyway have the updated part, the 03 Vibes have the problem... maybe some of the 04s do I don't know but I have fixed up a few 03 Vibes like that and it works.
