Buzzing in speakers
Reynoma
Buzzing in speakers
Post by Reynoma »
This is not a Vibe question, it is actually for my minivan.I had an aftermarket video system put in. Sound goes through an FM modulator. But, you can hear a very loud, anoying buzz sound that gets higher when I press on the gas. I guess it is feedback. Anybody know of anything I can do to eliminate this?
Philippians 2:11
Mr. Poopypants
Re: Buzzing in speakers (Reynoma)
Post by Mr. Poopypants »
It is electrical noise. I would guess, ITS JUST A GUESS, that the plug going from your cig lighter is picking up interference. I don't know what you could do to fix it though. Sorry for not being one bit of help.
probably not feedback, but ignition noise coupling in, especially if the pitch of the noise is related to RPMs.Maybe rerouting some wires, or perhaps a noise filter of some sort, maybe on the 12V to the modulator, or perhaps a better ground
drunkenmaxx
Re: Buzzing in speakers (Mr. Poopypants)
Post by drunkenmaxx »
my bro had one of those modulators and it picked up the firing of the spark plugs. he had to get a cheapy noise reducer from radio shack and problem solved.
Reynoma
Re: Buzzing in speakers (joatmon)
Post by Reynoma »
Quote, originally posted by joatmon »probably not feedback, but ignition noise coupling in, especially if the pitch of the noise is related to RPMs.Yeah, that is exactly what is happening.
Philippians 2:11
Reynoma
Re: Buzzing in speakers (drunkenvibe)
Post by Reynoma »
Quote, originally posted by drunkenvibe »my bro had one of those modulators and it picked up the firing of the spark plugs. he had to get a cheapy noise reducer from radio shack and problem solved.How involved is this "cheapy noise reducer"? I don't do this stuff myself, so I am probably better off bringing it someplace, right? (it has been about 2 years since the video unit has been put in).
Philippians 2:11
drunkenmaxx
it should just be plug and chug. in one end and out the other. if my bro could do it, anyone can!
Vibration
Post by Vibration »
Quote, originally posted by Reynoma »This is not a Vibe question, it is actually for my minivan.I had an aftermarket video system put in. You have "engine noise" or interference from a "ground loop." If you paid to have this installed, then take it back to them and make them fix it. Typical causes are loose power cables (especially the ground wire.) Usually, grounding all of the audio components to the same source will cure this problem. Worst case, have them ground your video system to your factory radio. The noise filters from Radio Shack can help, but they generally just reduce the noise, not completely eliminate it. It helps the symptoms, but does not cure the source of the problem.
nismo
Post by nismo »
hey, my brother suggested using a ground wire isulator. U can get it from Best Buy or Circuit City.Inder Singh
2008 Chevy Cobalt SS Turbo - Fun stuff under there somewhere 1998 Nissan Sentra - Sold2004 Pontiac Vibe - 107k and SoldCosmo CAI
Jahntassa
Post by Jahntassa »
Did you get it done at CC? If so, bring it back, they'll install that Groundloop isolator. If not, you can get one at Radioshack. It needs to be plugged into the RCA outputs of the DVD player.I've seen this many times, as i've installed quite a few at my CC store. PM me if you can't get ahold of the isolator.
Reynoma
Re: (Jahntassa)
Post by Reynoma »
Quote, originally posted by Jahntassa »Did you get it done at CC? If so, bring it back, they'll install that Groundloop isolator. If not, you can get one at Radioshack. It needs to be plugged into the RCA outputs of the DVD player.I've seen this many times, as i've installed quite a few at my CC store. PM me if you can't get ahold of the isolator.Thanks for all of the responses everybody. I had the video system put in at a high end electronics place called Tweeter (I don't know if they are only local or are nationwide). They are supposed to be the best. I'm thinking about going back there and having them fix it.
Philippians 2:11
Jahntassa
Post by Jahntassa »
Tweeter is definitely nationwide, and yeah, that'd be the best course of action. Engine noise is something we installers hate, and it isn't always obvious until AFTER the customer drives off. We usually warn our customers that there's a possibility of it popping up, in which case we'll troubleshoot it for you.
