Concern about engine idle when I start the car
R@@MPID
Post by R@@MPID »
When I start my Vibe.....and lately its been cold 10c the engine revs to about 2000 and after a couple of mins. drop to around 850.has anyone had the same problem or should go visit my dealer?Thanks
NSimkins
Global Moderator
Re: Concern about engine idle when I start the car (R@@MPID)
Post by NSimkins »
It's not a problem. Normal operation for these engines. See:http://forums.genvibe.com/zerothread?id ... d=1238Mine idles that way initially when the engine is cold and will remain there for a certain period of time, depending on the outside temperature.
R@@MPID
Re: Concern about engine idle when I start the car (NSimkins)
Post by R@@MPID »
thanks for the help.....I just found it wierd because my sunfire never did this (2.2 liter).but now i won't worry so much about because i'm not alone
NSimkins
Global Moderator
Post by NSimkins »
quote:thanks for the help.....I just found it wierd because my sunfire never did this (2.2 liter).My 2001 Cavalier Z-24 (2.4 liter) didn't either.. but it's an entirely different engine than the Vibe.quote:but now i won't worry so much about because i'm not aloneBetter to ask here than waste your time at the dealer, unless necessary.
cohocarl
Post by cohocarl »
Don't be concerned, mine does the same also.
