Ford Shelby GR-1 Concept
http://www.autointell-news.com...1.htm Quote »Ford Shelby GR-1 - Preliminary Specifications(Measurements in inches, unless otherwise noted) Length 173.7 (4413mm) Width 74.6 (1834mm) Height 46.0 (1168mm) Wheelbase 100 (2540mm) Track Front 63.0 (1598mm) Track Rear 61.3 (1558mm) Front Overhang 35.6 (903mm) Rear Overhang 38.2 (970mm) Min. Ground Clearance 5.9 (150mm) Curb Weight 3900 lbs est. Tire Size 275/40/R19 front 345/35/R19 rear Engine Ford 6.4L V10 Max RPM 7500RPM Horsepower 605 @ 6750RPM Torque 501lb/ft @ 5550RPM Transmission 6-speed transaxle with LSD Final Drive Ratio 3.36:1
kostby
Post by kostby »
The side view reminds me a lot of the Pantera. The V-10 screams 'Viper-bait'!
