When I was under the dash installing my LED's the other day, I went to pull the carpet up a bit right behind the shifter console to run some wiring. Then, a bolt fell out...I've got two possible explanations: It was dropped and lost at the factory, so they just used another bolt... Or the dealer may have dropped it down there when they replaced all the trim. Hopefully they replaced the missing bolt with another. Other than that, the dash hasn't been apart. Everything seems to be tight, nothing is rattling... I doubt I need it, but kinda curious where it came from.
