is the rear two motor mounts exactly the same shape except for the fact that one is skinny.i got a rear mount number 1173(other rear is 1174 fronts are 1175)that doesnt fit . the middle is slighly different and the mount is flat on one side.the instructions say this is sposed to be a 1113 but 1173 makes more sense numerically.is the instructions a typo or did i get the wrong mount.i had to pull the whole rear mount totally out the car and four hours later its back in with only the fat mount and no center bolt. i have to finish up tommorow.and then do it all over again but can i leave the three in till they send me four(hopefully).
Sorry Satur9, I cant help. When I got my clutch replaced, I just handed them My es mm insterts, and said " Here, put these in too" I did not know what was what, nor what #'s they were on the instuctions.-blisfully ignorant-Faultlne ...sorry man.
Quote, originally posted by satur9 »is the rear two motor mounts exactly the same shape except for the fact that one is skinny.i got a rear mount number 1173(other rear is 1174 fronts are 1175)that doesnt fit . the middle is slighly different and the mount is flat on one side.the instructions say this is sposed to be a 1113 but 1173 makes more sense numerically.is the instructions a typo or did i get the wrong mount.i had to pull the whole rear mount totally out the car and four hours later its back in with only the fat mount and no center bolt. i have to finish up tommorow.and then do it all over again but can i leave the three in till they send me four(hopefully).I put mine in today, and yes the rears are identical in contour. They only differ in thickness.
