Drivers seat problem
vibeman1
Post by vibeman1 »
hey guys,wanting to know if anyone has had a problem with there driver's seat, this just happen i the last couple of days,i noticed thatwhen i would get in or out of the vibe i heard a little popping noisethen today i'm standing at the drivers door and put i hand at the bottom and the other at the back and the hole seat moves,side to side and back and fouth,and i have also noticed the middle of theback of the seat is pushed in like a 500 lb person has been rockingback and forth in it. any one else had this problem?
David 2004 abyss - moon and tunes- power locks smokers package-all windows except winshield 35% tint-cargo storage-full frontend protectorcan't eat beef...mad cowcan't eat eggs..cholesterolcan't eat fish...mercurynow the way i see it:that only leaves--chocolate http://community.webshots.com/user/cobra42301
Atomb
Post by Atomb »
there's a joke there about having 2 people on the seat at the same time and a lot of 'moving around' but i won't go there! I had a VERY similar problem with my last car (VW) and it turned out to be a combination of 2 things....the bushings that the seat rides on underneath (that ride in the slots that the seat moves forward and back on) were loose and just needed a tigheting.the popping noise coupled with the indentation/sag of the back (the 500lb driver look) is probably caused by a few crucial tension seams breaking...take a look toward the back bottom of the seat (viewed from the back seat) and you might see some indications of a few of the 'tension/suspension' seams that have snapped.
vibeman1
Post by vibeman1 »
update on the driver's seat problem, dealer was vary concered about this loose seat,even they are not for sure what the problem is at this point but they think it's the lsft rail,they ordered for me today,and will install under warrenty when it comes in.they said if that don't fix the problem they will order a new seat with all new hardware,they even went out to the new cars and found a vibe with the hight adjuster on it to see if they could make it move,they pulled,tugged and more but the new vibe seat wouldn't budge,they said they really wanted to get to the bottom of this problem because it could be a safty issue.if you seat in the back seat and push on the top of the drivers seat it will move 1/2- to 1 in or more,they also said they was concerned this may be a defect in the vibe. i'll post things as it develops mean time i would advise all owners to do the test above and see if your drivers seat does this.
nismo
Re: Drivers seat problem (vibeman1)
Post by nismo »
Do you happen to lean up to get your wallet or anything out of your back pocket? Or in that case, Do you lean against your back at all? If you do, try to tighten down the bolts that hold the seat down and if that doesn't work, go to the dealer. See what he says.Inder Singh
vibeman1
Re: Drivers seat problem (TRD4reel)
Post by vibeman1 »
Quote, originally posted by TRD4reel »Do you happen to lean up to get your wallet or anything out of your back pocket? Or in that case, Do you lean against your back at all? If you do, try to tighten down the bolts that hold the seat down and if that doesn't work, go to the dealer. See what he says.Inder Singhread the above i have already taken it to the dealer.there is a driver's seat problem. besides you should be able to get your billfold out of your pocket,or sit in your seat with your back on the back of the seat without braking it,the car has less then 3000 mile on it......duh
AKLGT
Post by AKLGT »
nope not a prob in mine. but i did loosen the passengers side bolt for the seatbelt.. not a warranty thing since i believe i didn't tighten the bolt enough when i reinstalled the seat last summer.
AKLGT1998 Subaru 2.5RS
Mavrik
Re: Drivers seat problem (trdvibe)
Post by Mavrik »
I think you were just trying to kill me Hope by having me fly through your windshield.
AKLGT
Re: Drivers seat problem (Mavrik)
Post by AKLGT »
it was a test. you passed.
