Dent poppers, anyone got one?
Mavrik
Post by Mavrik »
If anyone looks in the Vibe warranty and problems forum there is a thread by me about some dents I discovered on my car. If anyone has a dent popping kit that you think might work and your going to be at the MI meet could you let me know? I'd like to borrow it to pop them out at the meet or I'll be paying someone to do it afterwards cause they look awful and I need to get them removed. Thanks!
Stang2Vibe
Re: Dent poppers, anyone got one? (Mavrik)
Post by Stang2Vibe »
We've got a few slide hammers at work, but that is not what you're going to be looking for. It would require drilling the body panels and putty and paint work to complete the job. I've seen a couple of the type of dent poppers that you are looking for and I hear that they generally work quite well. I hope you can find one and avoid the costs of repairs.
Sub-Vibe-R
Post by Sub-Vibe-R »
You can get one at Canadian Tire for $30http://www.canadiantire.ca/(removed)...imarySo why borrow one when you can have your own
ebslopp
Re: Dent poppers, anyone got one? (Sub-Vibe-R)
Post by ebslopp »
I have one, but I won't be at the MI meet. You can use it if you stop by Madison. I doubt it'd be on your way though. I picked it up at Target for $20. Works like a charm. Perfect for your type of dents.
Mavrik
Re: Dent poppers, anyone got one? (ebslopp)
Post by Mavrik »
Thanks, sounds like I'll be taking a spin past canadian tire before the weekend.
Quote, originally posted by ebslopp »I have one, but I won't be at the MI meet. You can use it if you stop by Madison. I doubt it'd be on your way though. I picked it up at Target for $20. Works like a charm. Perfect for your type of dents. Would that be the Ding King?I saw that thing on TV, didn't think it actually worked...does it?If so, I got a nice sized dent on my driver door that's been bugging me to hell...
savedbyzero
Re: Dent poppers, anyone got one? (ragingfish)
Post by savedbyzero »
On the infomercials, it seems to remove the dent, but add 2 more where the 2 anchors sit against the car. Are they worth it?
THIS IS WHAT I DO...http://www.studiothisis.com
ebslopp
Re: Dent poppers, anyone got one? (savedbyzero)
Post by ebslopp »
I have the Ding King. I used it to remove two smaller dents from the hood of my Civic when some jack@55 sat on my car. It does work very well for small dents (grapefruit sized), but will have a tough time with very large dents (soccer ball sized). Probably would not work at all if there is any creasing. It doesn't leave dents like zero suggested. But this would be perfect for Mavrik's dents.
Hmmm, I might have to try it. My door dent is about softball-sized. It looks like it should pop right out.
savedbyzero
How about door dings?
ebslopp
Post by ebslopp »
Haven't had the opportunity to try it on a door ding (thankfully). It did come with a couple of different size parts for different size dents though. One was supposed to be for door dings.
AKLGT
Post by AKLGT »
Quote, originally posted by ebslopp »I have the Ding King. I used it to remove two smaller dents from the hood of my Civic when some jack@55 sat on my car. It does work very well for small dents (grapefruit sized), but will have a tough time with very large dents (soccer ball sized). Probably would not work at all if there is any creasing. It doesn't leave dents like zero suggested. But this would be perfect for Mavrik's dents. well, phil, it's worth a try! if it doesn't then will have to figure out something else.
AKLGT1998 Subaru 2.5RS
I'd like to thing it would work somewhat well on doors...after all, I think door sheet metal is about as plyable as hood metal...if not a bit more...KWIM?
savedbyzero
Hmmm, i'm scared to try it. The commercial scares me.
Sub-Vibe-R
Quote, originally posted by savedbyzero »Hmmm, i'm scared to try it. The commercial scares me.May be, but it worth a try.The other way to fix it is to fill up dent with putty and repaint the entire part. And for $30, you have almost nothing to loose
AKLGT
Post by AKLGT »
Quote, originally posted by Sub-Vibe-R »May be, but it worth a try.The other way to fix it is to fill up dent with putty and repaint the entire part. And for $30, you have almost nothing to looseexactly! nothing to lose at this point. unless you can prove to GM that it is indeed a stress point...
savedbyzero
Re: Dent poppers, anyone got one? (trdvibe)
I was actaully referring to the door dings I have. I'd be scared to use it on my car. Especially with the dings being the soft spot of the door. I couls end up with 3 dents instead of one! Mavrik should definitely try it. Nothing to lose there.
Sub-Vibe-R
Quote, originally posted by Mavrik »Thanks, sounds like I'll be taking a spin past canadian tire before the weekend. Any feedback Mavrik.I found a dent on my front fender (probably caused by body flex while cornering) and would be great to remove it. It seems to only bother me (it is hard to see) but I know it is there and I want to remove it without repainting the whole thing.
ArcsVibe
Post by ArcsVibe »
Hey Phil now don't laugh at what I am going to tell you but it actually works and I tried it on my 96 Cavalier when I had a nasty little dent......I actually used a toilet plunger LOL and it worked like a charm....try that first and oh yeah make sure its clean first
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
mojo_jojo
Post by mojo_jojo »
I've got the Ding King too. Picked it up at target for about $20. And yes it does work. I used it on my wife's previous car a 2002 Buick rendezvous CXL. She hit our plastic mailbox and left quite a dent in the rear passenger door and rear quarter. It took me most of an afternoon to remove the dent(s). I can tell you that my handy work passed the lease turn-in inspection on the Buick, no excessive wear and tear as per the inspector. I wish I would have taken some before and after pics to illustrate. The thing will work, just need to be patient and make sure the area to be worked on is clean of dirt and wax. I ran out of the mystery fluid that came with the Ding King, but I can tell you that mineral spirits work just fine.
2004 AWD mono-tone Abyss, moon and tunes, power group
Sub-Vibe-R
Re: Dent poppers, anyone got one? (ArcsVibe)
Quote, originally posted by ArcsVibe »Hey Phil now don't laugh at what I am going to tell you but it actually works and I tried it on my 96 Cavalier when I had a nasty little dent......I actually used a toilet plunger LOL and it worked like a charm....try that first and oh yeah make sure its clean first Yes the toilet plunger works, but with big dents (size of a soccer ball) but I doubt it will work with small one like Mavrik has...
Well, I tried the ding king, and it's been dethroned. Didn't pull out my dent at all. I spent a good 20 minutes, each time I tried popping the dent, removing the glue it left behind. What a PITA, and it didn't help at all.
Sub-Vibe-R
Re: (ragingfish)
I bought one as well.I have a very small dent on my front driver fender.I tried to remoce this dent 3 times and it never worked.But hte dent is so little... it could be then answer. Probably if the dent was bigger it would work....
