Musky smell when A/C is on
makr0jeff
Post by makr0jeff »
I turned my air conditioner on a few days ago and the a cabln filled with a wet mildew'y smell. Anyone know what would cause this? I was thinking cabin filter, how often should I change it.thanks guys
JohnC
Re: Musky smell when A/C is on (makr0jeff)
Post by JohnC »
To prevent this in the future, just run the fan on high in the vent mode (a/c off, recirc off) for several minutes before shutting the car off. This will dry out the a/c evaporator condensation that causes the odor. This is a very common problem on all vehicles, although some drain better than others.
Re: Musky smell when A/C is on (JohnC)
Quote, originally posted by JohnC »To prevent this in the future, just run the fan on high in the vent mode (a/c off, recirc off) for several minutes before shutting the car off. This will dry out the a/c evaporator condensation that causes the odor. This is a very common problem on all vehicles, although some drain better than others.I'll second that. When I'm close to my destination, I'll usually kick off the A/C, crank up the fan, and make sure that the fresh air mode is selected. Otherwise, the water is sitting there in the system, stagnant. That stinks. Also, I've found in the past, if you run in recirculate mode too often, it could cause a bit of a stink as well.
