Supercharger what?
vibe_raider
Supercharger what?
Post by vibe_raider »
I have 4k to blow on my summer vibe project. And I've been told I "have to get a supercharger" ... unfortiantly, i know absolutely nothing about the supercharger for the vibe... how much will it cost me and how much more *umph* will it get me?
My other ride is a ...
AKLGT
Re: Supercharger what? (vibe_raider)
Post by AKLGT »
well, that's sweet! check out this forum: forced induction you can also do a search for the s/c info... w/ the help of some aftermarket engine management, you can run some very impressive numbers!
AKLGT1998 Subaru 2.5RS
wicked1981
Post by wicked1981 »
Here. For price call your nearest dealer and ask. Part # in the website below.http://www.gmgoodwrench.com/gm...on=pp
Mavrik
Re: Supercharger what? (wicked1981)
Post by Mavrik »
You'll have lots of power and probably none of that 4k when your done lol.Gains are 35% increase on torque and HP.
goodvibe
Re: Supercharger what? (Mavrik)
Post by goodvibe »
Remember that those percentages are not at peak numbers. Closer to 20% with a great torque curve and well worth it on a base.
Evanshall
Post by Evanshall »
and keep in mind its for the Vibe not the Vibe GT, just incase!! im sure you know which vibe you got, but beleive it or not they onlly make the supercharger for the base vibe, i think it could work on AWD just isnt recommended for whatever reason(All wheeld drive model has the same engine as Base Vibe)Base Vibe/AWD Vibe=VVT-i 1ZZ EngineVibe GT=VVTL-i 2ZZ Enginei have 2k to possibly blow but i dought ill get to blow any of it as well raider if you have any money left over a "Unichip" will not only help performance, but Gas milage, and overall engine stability, it goes for about 730 USD, about what would be left over after purchasing a Supercharger, it will help alot!!, in basically every way possible
Quote, originally posted by vibe_raider »I have 4k to blow on my summer vibe project. And I've been told I "have to get a supercharger" Man, that's a some bad luck there. j/k, wish someone would give me $4K and tell me I had to spend it on a SC for my vibe I see a bunch of threads when I search topic titles for superc*
goodvibe
Re: Supercharger what? (joatmon)
Post by goodvibe »
Who needs a superc* when you've got a viberaider?
wicked1981
Re: (Evanshall)
Quote, originally posted by Evanshall »and keep in mind its for the Vibe not the Vibe GT, just incase!! im sure you know which vibe you got, but beleive it or not they onlly make the supercharger for the base vibe, i think it could work on AWD just isnt recommended for whatever reason(All wheeld drive model has the same engine as Base Vibe)Base Vibe/AWD Vibe=VVT-i 1ZZ EngineVibe GT=VVTL-i 2ZZ EngineIf im not wrong I think the SC has been installed in an AWD model.
