water in the floor
ullbergm
water in the floor
Post by ullbergm »
This started about a week ago when i though i had spilled a big bottle of water in the floor on the passenger side.I said some choice words and used the shopvac to get most of it out. Well, ever since that day ive been vacuuming out more water and im pretty sure that this is way more than could have been in that bottle.It is in both the front and the back part of the passenger side. Is it possible that i have a leak somewhere around the door? It has been raining pretty hard around here for a couple of days. Where should i start looking? It's supposed to storm tonight, im thinking about going out to the car and see if i can see any leaks.
Car: Two-tone Base Abyss, Moons and tunes, Power packageMods: 20% tint, Reflective Black GrafxWerks Overlays, German Hella Horns, Hardwired Valentine One, red interior dome lights, custom cargo floormat, police scanner, ham radio, cellphone kit and a bunch of antennas on topWishlist: Rubber floormats, million dollars
ullbergm
Re: water in the floor (ullbergm)
Post by ullbergm »
This is what it looks like.
daaamn...that's a lot of water!!!!definitely doubt it's an A/C condesor leak...i'd venture to say a door seal leak, or maybe the moonroof drain leak...either way, might wanna throw a tarp over the car so it doesn't get too much water in it...you may not be able to fix the problem now, but you can at least keep it from getting worse
ullbergm
Re: water in the floor (ragingfish)
Post by ullbergm »
Quote, originally posted by ragingfish »daaamn...that's a lot of water!!!!definitely doubt it's an A/C condesor leak...I did see that the line to the rear windshield sprayers run on that side, but it doesnt smell like windshield washer fluid. (or anything else for that matter).atleast its just water, could be worse i guess.Quote, originally posted by ragingfish »i'd venture to say a door seal leak, or maybe the moonroof drain leak...either way, might wanna throw a tarp over the car so it doesn't get too much water in it...you may not be able to fix the problem now, but you can at least keep it from getting worseThe ceiling doesnt seem to be wet, so its probably around the door. If it storms tonight i'll watch it and if it leaks ill put a tarp over it.
Devlop
Post by Devlop »
Another thing you can do is to sit inside and have someone with a garden hose spray the car around all the seals. This will help figure out at which point the water is leaking in at. Make sure you hose down along all the doors and the windshield.If you're still under warranty, just take it to your dealer and let them deal with it. I'm sure they'll give you a rental.
scherry2
Post by scherry2 »
just a suggestion but,the lines for the moonroof run down each a pillar you might want to check and see if they are exiting the car where they should be. the moonroof has drains on all 4 corners. the front hose run down each a-pillars and the rear i think run down the side of the roof and exit behind the rear tires by the pressure relief valve. return to the dealer and have them check it out with water still there or they will say they can't duplicate it.
Fialchar
Re: water in the floor (scherry2)
Post by Fialchar »
This may sound stupid, but I know I've overlooked a lot of really simple things before, it's easy to do so. Have you checked to see if the window on the side was rolled down a tiny bit?
ullbergm
Re: water in the floor (Devlop)
Post by ullbergm »
Quote, originally posted by Devlop »Another thing you can do is to sit inside and have someone with a garden hose spray the car around all the seals. This will help figure out at which point the water is leaking in at. Make sure you hose down along all the doors and the windshield.If you're still under warranty, just take it to your dealer and let them deal with it. I'm sure they'll give you a rental.Good point, dont know why i didnt think of that
ullbergm
Post by ullbergm »
Quote, originally posted by scherry2 »just a suggestion but,the lines for the moonroof run down each a pillar you might want to check and see if they are exiting the car where they should be. the moonroof has drains on all 4 corners. the front hose run down each a-pillars and the rear i think run down the side of the roof and exit behind the rear tires by the pressure relief valve. return to the dealer and have them check it out with water still there or they will say they can't duplicate it.Really? I learned something new today. I didnt realize there were drains for the moonroof. Thanks
ullbergm
Re: water in the floor (Fialchar)
Post by ullbergm »
Quote, originally posted by Fialchar »This may sound stupid, but I know I've overlooked a lot of really simple things before, it's easy to do so. Have you checked to see if the window on the side was rolled down a tiny bit?That is something that i'd forget.. but this time i did check it. thanks thou.
Fialchar
Post by Fialchar »
No problem, I don't know about the Vibe's seals and drains, so the best I can do now is say Good luck.
ullbergm
Re: water in the floor (Salsa!)
Post by ullbergm »
Quote, originally posted by Salsa! »LOL...who could hold his/her water???
Seej
Post by Seej »
Did you resolve this issue?I am having the same problem.I discovered it on a trip from Michigan to Missouri.I'm heading back to Michigan next week.. then at the end of the month, I am heading to Kentucky.If you can post as much info as possible, I might be able to get it fixed before I head to Kentucky Thanks!
ullbergm
Re: water in the floor (Seej)
Post by ullbergm »
Quote, originally posted by Seej »Did you resolve this issue?I am having the same problem.I discovered it on a trip from Michigan to Missouri.I'm heading back to Michigan next week.. then at the end of the month, I am heading to Kentucky.If you can post as much info as possible, I might be able to get it fixed before I head to Kentucky Thanks!I'm not sure.. I re-ran a wire that i had run on that side of the car and i have yet to test it using a water hose. I've been parking in the garage lately so i dont know if its fixed or not. but its something that is definately on my todo list.
Atomb
Post by Atomb »
this might be a dumb question, but could this be the problem?>http://forums.genvibe.com/zerothread?id=10202(plugged A/C drain)
ullbergm
Re: (Atomb)
Post by ullbergm »
thanks,i'll have to take a look at that. any idea where it is?If its in the manual, just say so.. i dont mind looking but im at work right now.
ullbergm
Re: (ullbergm)
Post by ullbergm »
Quote, originally posted by ullbergm »thanks,i'll have to take a look at that. any idea where it is?If its in the manual, just say so.. i dont mind looking but im at work right now.Thanks!That's be it. Mine was actually unplugged all the way.If the carpet molds (i see some white stuff under there) would this be a warranty thing you think?
Re: (ullbergm)
Wow, that's the same thing that 87iroc had happen to his... Sounds like they put this drain tube in a bad location!I would hope the dealer would replace the carpet... I had a nasty A/C leak in my old Malibu, once they finally were able to find and supposedly repaired the leak, I made them replace the carpet. The problem cropped up within the first week, by the end of the first month of ownership, the new car smell was gone. It continued to leak, so once I knew it was fixed for good, I made them replace it again. Definitely don't wanna mess around with that stuff!If it's been leaking for a while, demand some new carpet!
ullbergm
Re: (ColonelPanic)
Post by ullbergm »
Quote, originally posted by ColonelPanic »Wow, that's the same thing that 87iroc had happen to his... Sounds like they put this drain tube in a bad location!Yup, be carefull if you put your feet forward and to the left in the front passenger area. I'm going to ziptie the hose to make sure this doesnt happen again.
ullbergm
Re: (silverawd26)
Post by ullbergm »
Quote, originally posted by silverawd26 »I would not zip tie it, go down to the local hardware store or Lowes/Home Depot and get a compression hose clamp, you know, the fuel line type for lawn mowers.good point, i'll do that instead. thanks
jasonbourne
Re: (Atomb)
Post by jasonbourne »
hey, i am from toronto, but i live in houston now:( i miss home!
ToolGuy
Re: (silverawd26)
Post by ToolGuy »
Quote, originally posted by silverawd26 »I would not zip tie it, go down to the local hardware store or Lowes/Home Depot and get a compression hose clamp, you know, the fuel line type for lawn mowers.I would not use a metal clap... The plastic can crack if over tightened and if so, it will create more of an issue. There is no pressures or liquid like a metal clamp needs to secure and nothing touches the tube that could grab it and knock it off. I used a Tie Wrap and it holds tight enough. GM recommends a tie wrap.
Again, the power of genvibe.Was touristing an older relative around the local sights, and running the AC a lot more than usual, she noticed the front passenger floor was wet. Having read about this problem over the last four years, I knew what to check, and it was obvious the water came from the disconnected AC drain hose. easy to fix, and hot enough out to dry out the carpet in a few hours in the sun. Thanks genvibe
