Swapping out a NAV unit for another unit
jbernie1
Post by jbernie1 »
Can you swap a NAV stock unit for in CD radio? I already have a CD changer.
Re: Swapping out a NAV unit for another unit (jbernie1)
You can swap out the Nav for an in-dash player (6 disc or single disc), but cannot reuse the changer. The other two head units have no way to interface with that changer.
esjones
Re: Swapping out a NAV unit for another unit (ragingfish)
Post by esjones »
What do you know about the changer? I see it is made by Pioneer. Do changers have a common method of connection to head units? If possible, I'd like to swap my CD changer out for a Mini-Disc changer.Thanks.
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
Jahntassa
Post by Jahntassa »
Nope. No can do. As far as I know, the only company that made MD changers is Sony, and you can only interface sony changers with sony HU. The fact that the Nav system has a Pioneer changer is a misnomer. The changer uses the GM 12pin interface, and not IP-Bus (the Pioneer standard). You might be able to change the changer for another GM 6-disc, but that's probably it. I don't think anyone makes a GM 12-pin interface to a Sony changer.Also, Mike is correct, neither the stock 1-disc or the in-dash 6-disc will work with the Nav changer.
blk182@n7
Post by blk182@n7 »
ill trade the my 6 disc for the nav unit
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
