Tips for Bounce Fabric Softener
Alternative uses for Bounce Fabric Softener Sheets:Quote »Repel mosquitoes.Tie a sheet of Bounce through a belt loop when outdoors during mosquito season.Eliminate static electricity from your television screen. Since Bounce is designed to help eliminate static cling, wipe your television screen with a used sheet of Bounce to keep dust from resettling.Dissolve soap scum from shower doors. Clean with a used sheet of Bounce.Freshen the air in your home. Place an individual sheet of Bounce in a drawer or hang one in the closet.Prevent thread from tangling. Run a threaded needle through a sheet of Bounce to eliminate the static cling on the thread before sewing.Eliminate static cling from pantyhose. Rub a damp, used sheet of Bounce over the hose.Prevent musty suitcases. Place an individual sheet of Bounce inside empty luggage before storing.Freshen the air in your car. Place a sheet of Bounce under the front seat. Clean baked-on food from a cooking pan. Put a sheet in the pan, fill with water, let sit overnight, and sponge clean. The antistatic agents apparently weaken the bond between the food and the pan while the fabric softening agents soften the baked-on food.Eliminate odors in wastebaskets. Place a sheet of Bounce at the bottom of the wastebasket.Collect cat hair. Rubbing the area with a sheet of Bounce will magnetically attract all the loose hairs.Eliminate static electricity from venetian blinds. Wipe the blinds with a sheet of Bounce to prevent dust from resettling. Wipe up sawdust from drilling or sandpapering. A used sheet of Bounce will collect sawdust like a tack cloth.Eliminate odors in dirty laundry. Place an individual sheet of Bounce at the bottom of a laundry bag or hamper.Deodorize shoes or sneakers. Place a sheet of Bounce in your shoes or sneakers overnight so they'll smell great in the morning. "Bounce" is a registered trademark of Procter & Gamble.
wicked1981
Re: Tips for Bounce Fabric Softener (ragingfish)
Post by wicked1981 »
Jeez didnt know they were this useful. Im gonna use 2 or 3 of those tips.
savedbyzero
Re: Tips for Bounce Fabric Softener (wicked1981)
Post by savedbyzero »
This has to be the most random topic ever posted on here!
THIS IS WHAT I DO...http://www.studiothisis.com
Herb
Re: Tips for Bounce Fabric Softener (savedbyzero)
Post by Herb »
Quote, originally posted by savedbyzero »This has to be the most random topic ever posted on here!Maybe we can start calling Mike "Marty Stewart"I might test a couple if the ideas out later though.
rasermon
Re: Tips for Bounce Fabric Softener (Herb)
Post by rasermon »
Quote, originally posted by Herb »Maybe we can start calling Mike "Marty Stewart" Just stay away from the stock market or you will be doing some time. I've found that 100% DEET unscented lasts up to 10 hours for areas heavily infested with mosquitoes and where protection is needed for an extended period of time.
Raven
Re: Tips for Bounce Fabric Softener (rasermon)
Post by Raven »
Maybe if you put about 50 sheets in a Vibe, you wouldn't get a huge static shock every time you get out like I do. I'm sick of it!
savedbyzero
Re: Tips for Bounce Fabric Softener (Sunny)
Quote, originally posted by Sunny »Maybe if you put about 50 sheets in a Vibe, you wouldn't get a huge static shock every time you get out like I do. I'm sick of it!(removed)!
Herb
Post by Herb »
Quote, originally posted by Sunny »Maybe if you put about 50 sheets in a Vibe, you wouldn't get a huge static shock every time you get out like I do. I'm sick of it!Maybe someone can reupholster a Vibe using Bounce sheets!
Mr. Poopypants
Post by Mr. Poopypants »
We may have to bump Bounce up into the WD40 catagory after reading that, still not as useful as duct tape though.
drunkenmaxx
Re: Tips for Bounce Fabric Softener (Mr. Poopypants)
Post by drunkenmaxx »
another use famous among the tokers:-get an empty paper roll, fill it with dryer sheets.-after you take a big rip, blow the smoke through the roll.-out comes clean, mountain fresh air! mom will think you've been doing some cleaning!note: this does not work on doobies.disclaimer: this is not in any way endorsing or encouraging cannabis use
Quote, originally posted by Sunny »Maybe if you put about 50 sheets in a Vibe, you wouldn't get a huge static shock every time you get out like I do. I'm sick of it!Try spraying your seats with one of those anti-static aerosol sprays...We use to spray our TV's at target so the customers didn't get shocked when they got near the screens (also to keep dust from being attracted to the screens).
Stang2Vibe
Post by Stang2Vibe »
I realized how useful Bounce really is. I've tried a few of those before and they worked pretty well. Now I have some uses for my used dryer sheets as well! Cool!I wonder if I can take out the cabin air filter from behind the glovebox in the Vibe and cover it with a Bounce sheet then reinsert it. Then when the fan is blowing air, it will be springtime fresh!
Re: Tips for Bounce Fabric Softener (Stang2Vibe)
Make sure you stick it on the underside of the filter...the intake air goes from bottom to top. If you put it on top, it'll just blow off into the system.
