JL Audio Tweeters - will they fit?
fuente2000
Post by fuente2000 »
Does anybody know if the JL Audio component tweeters will fit where the stock tweeters are in the window corners? Don't want to start taking things apart only to find out they don't fit... if you know what I mean.Thanks
2004 Vibe Base (Shadow), 18" HP Racing Wheels with 235/40x18 Michelin, Progress Sway Ant-Sway Bar, Magnaflow Catback Exhaust, Sylvania Silverstars, Megan Racing Upper Strut Bar, Eibach Proline Springs, and more to come!! http://www.cardomain.com/memberpage/605576
Jahntassa
Post by Jahntassa »
They probably should. I have a pair of polk's up where the stock tweeters are, and I know the infinity's fit. I'm pretty sure they're all the same (similar) size..I'd say you won't have a problem.
prtlnd03gt
Post by prtlnd03gt »
are the stock door tweeters 2"??
