Check Engine Light (CEL) codes
Found someone posted a softcopy of the 2004 Matrix manual, and I grabbed the check engine light code lists from there, and posted them at 2004-1ZZ-CELcodes.pdf and 2004-2ZZ-CELcodes.pdf Both are small, about 40 KB, and apply to Vibes as well as Matrix. The codes are the same for 2003 models, except that there are a few new ones for 2004. For example, you won't get a P2441 on a 2003 GT because the 2003 didn't have the smog pump introduced in the '04.(MIL = malfunction indicator light = check engine light = CEL)edit 2/12/08 rehosted and updated urls to pdfs
pmh013
Re: Check Engine Light (CEL) codes (joatmon)
Post by pmh013 »
Thanks for the link! I printed out the pertinent page, and it will be coming with me to the dealership on Monday.
myredrs
Post by myredrs »
Thanks. I'll keep them handy. Greg
2003 Abyss Two-Tone Vibe GT AEM CAIMagnaflow Cat-backProgress RSB17" Falken Torque5(Gunmetal) RimsHotchkis SpringsCross Drilled/ Slotted Brakeshttp://www.cardomain.com/ride/670160
meem
Post by meem »
Could you tell me what the difference is between the 1ZZ and the 2ZZ?Thanks
Re: Check Engine Light (meem)
Quote, originally posted by meem »Could you tell me what the difference is between the 1ZZ and the 2ZZ?Thanks1ZZ and 2ZZ are the engine codes. The 1ZZ engine is the engine that is in base Vibes, and AWD vibes. The Vibe GT gets the 2ZZ engine. Similary, Matrix and Matrix XR FWD and AWD get the 1ZZ, Matrix XRS has the 2ZZ.
thorntcl
Re: Check Engine Light (joatmon)
Post by thorntcl »
Sorry old thread, but does anyone have the CEL codes still? The links provided here don't seem to work anymore?Cheers
Cheersthor...2004 Base VibeAutomatic, black abyssTint 35 front and 20 backWish list:auto start/remote entry/lock for all doors. (no factory pwr doors or windows)
Re: Check Engine Light (thorntcl)
Quote, originally posted by thorntcl »Sorry old threadYou calling this thread sorry and old?Yeah, I forgot that host went away, so today I rehosted the files and updated the links. Should work now
thorntcl
Post by thorntcl »
yeah yeah, bad choice of words I supposeThanks so much for the codes!!!Cheers
