Master Parts Listing
Pontiac, GM SPO (Service Parts Organization) & TRD (Toyota Racing Development) discussions
It seems we, on many occasions, have learned of new part numbers for little things throughout the car. I've decided to create a thread that will condense all these discoveries into one comprehensive parts listing.If you have a part number that you would like to contribute to this list, please let me know, or post here. If you choose to post part numbers here, I will add them to the list after confirming accuracy, and subsequently delete your post. US Part Numbers are used. May not match Canadian part numbers.Some parts may be applicable to certain model years. They will be designated as such.Prices are no longer being provided because of the rapidly changing prices of parts.You can check the approximate price of any item at either of the following sites: GM Parts Direct Parts Zone OnlineNOTE: The Toyota logo () indicates a Toyota part number.
Re: Master Parts Listing (ragingfish)
Last Update: 11/08/04 ACCESSORIES AND ACCESSORY PACKAGES12498278, Active Package - FWD12498279, Active Package - AWD10952544, Battery Heater 80 Watt - 110V12495021, Bicycle Carrier Fork Mounted12498267, Bumper Protector12498133, Cargo Area Mat (Will not fit 2005 models with Monsoon subwoofer)17800790, Cargo Area Mat (2005 w/ M&T ONLY)12498132, Cargo Nets12498559, Cargo Organizer Multi-Purpose12370237, Distress Strobe Light12498310, Engine Block Heater12497926, Exhaust Tips - Bolt on RPA - Code NBG12498111, Floor Mats, Vinyl Rear Set, Base/GT12498155, Floor Mats, Vinyl Rear Set, AWD12498520, Floor Mats, Vinyl Front Set, All Models999681, Food & Bev AC Adaptor999679, Food & Beverage Warmer/Cooler *Discontinued*12498126, Front-End Cover w/o Logo (Includes hood cover)12498339, Graphics, Bodyside Silver (Requires two per vehicle) 12497328, Highway Emergency Kit12498125, Hood Cover Only w/o Logo12497374, Mobile Office Organizer12498661, Pet Safety Harness & Tether Kit Seat belt attachment (Small pet)12498662, Pet Safety Harness & Tether Kit Seat belt attachment (Medium pet)12498663, Pet Safety Harness & Tether Kit Seat belt attachment (Large pet)12498684, Roof Rack Utility Bars12498113, Seat Backpack Black12498134, Seat Covers, Water-Resistant Front and Rear Set12498152, Seat Covers, Water-Resistant Front Set12498153, Seat Covers, Water-Resistant Rear Set12498266, Seatback Storage w/ First Aid Kit12495610, Ski Carrier Roof Mounted, Holds 6 pairs of skis or 4 snowboards12497853, Ski Carrier Roof Mounted, Holds 4 pairs of skis or 2 snowboards12498056, Splash Guards, Molded Front Set - ALL YEARS MONO, 2003 2TONE ONLY IF NO RKR EXT12498057, Splash Guards, Molded Rear Set12498805, Spoiler Package Salsa12498807, Spoiler Package Abyss12498808, Spoiler Package Satellite12498809, Spoiler Package Primed12498773, Sport Package Salsa12498774, Sport Package Abyss12498775, Sport Package Satellite12498806, Sport Package Primed12498927, Supercharger - AT12499105, Supercharger - MT12378454, Vehicle Car Care Kit12498261, Vent Visors12495014, Visor CD/DVD Holder12499855, Splash Guards, Molded Front Set - 2003 2TONE W/ RKR EXT, 2004+ 2TONEPAINT, TOUCH UP12346659, Paint, NeptuneABS/BRAKES88969672, Sensor, Front ABS - RH88969673, Sensor, Front ABS - LH88970134, BPMV Unit, Base/GT88970135, BPMV Unit, AWD88971116, Bracket, BPMV88971202, Booster Assy, Brake88971203, Valve, Check88971205, Cylinder Assy, Brake Master, w/ ABS, MT88971207, Cylinder Assy, Brake Master, w/o ABS, MT88971206, Reservoir Assy, MT88971208, Cylinder Assy, Brake Master, w/ ABS, AT88971209, Reservoir Assy, AT88971210, Cylinder Assy, Brake Master, w/o ABS, AT88972183, Filter, Reservoir94851263, Grommet, Reservoir94853034, Cap, Reservoir94857030, Grommet, Check ValveAIR BAG SYSTEM88969204, Module, Driver Air Bag88969488, SDM Unit, w/o Side Air Bag88969490, SDM Unit, w/ Side Air Bag88969493, Sensor, Front End - RH88969494, Sensor, Front End - LH88969498, Sensor, Front Passenger88969652, Coil, SIR88970591, Module, Passenger Air Bag88970623, Back, Seat, w/ Side Air Bag, Light Gray, Passenger88970624, Back, Seat, w/ Side Air Bag, Dark Gray, Passenger88970625, Back, Seat, w/ Side Air Bag, Light Gray, Driver88970626, Back, Seat, w/ Side Air Bag, Dark Gray, Driver88972227, Module, Side Air BagAIR CLEANER17801-0D020, Air Filter, Engine 88969107, Element, Air FilterCARGO AREA88973453, Subwoofer Enclosure/Panel - 2005+CENTER CONSOLE88971514, Center Console Hidden Electrical Receptacle Cover88971515, Center Console Hidden Electrical ReceptacleCOOLING SYSTEMS88969094, Radiator Assy, Manual Transmission88969096, Radiator Assy, Automatic Transmission88969097, Cusion, Upper Radiator (R/L)88969098, Bracket, Upper Radiator (R/L)88969099, Hose, Upper Radiator88969100, Hose, Lower Radiator (Base, AWD)88969101, Hose, Lower Radiator (GT)88969161, Pipe Assy, Trans Cooler Inlet (Base)88969162, Hose, Trans Cooler Inlet (Base) (2) 88969162, Hose, Trans Cooler Outlet, Front (Base)88969163, Hose, Trans Cooler Outlet, Rear (Base)88969164, Pipe Assy, Trans Cooler Outlet (Base)88969165, Pipe, Trans Cooler88969166, Pipe Assy, Trans Cooler Inlet (AWD)88969167, Insulator, Pipe (AWD)88969168, Hose, Trans Cooler Inlet (AWD) (2)88969168, Hose, Trans Cooler Outlet (AWD) (2)88969169, Pipe Assy, Trans Cooler Outlet (AWD)88969174, Bracket, Clamp88969593, Pulley, Water Pump (GT)88969595, Gasket, Water Pump (GT)88969604, Housing, Thermostat (GT)88969605, Thermostat88970212, Tensioner, Drive Belt (GT)88970232, Belt, Drive (GT)88970731, Support, Upper Bracket (R/L)88971516, Fan, Cooling, Manual Transmission88971517, Motor, Fan, Manual Transmission88971518, Cap, Coolant Reservoir88971521, Fan, Cooling, Automatic Transmission88971522, Motor, Fan, Automatic Transmission88971576, Belt, Drive (Base/AWD)88972165, Pump Assy, Water (Base)88972166, Pump Assy, Water (GT)88972167, Pump Assy, Water (AWD)88972524, Shroud w/ Reservoir, Fan94853446, Clamp, Cooler Pipe94853450, Insulator, Pipe (Base)94853503, Cap, Radiator94856769, Gasket, Water Pump (Base/AWD)94856781, Gasket, Thermostat Housing94859856, Housing, Thermostat (Base/AWD)94860009, Tensioner, Drive Belt (Base/AWD)CRUISE CONTROL SYSTEM88969660, Servo, Cruise Control88969661, Cover, Servo88969662, Bracket, Servo88969666, Module, Cruise Control, Base88969667, Module, Cruise Control, AWD88969668, Module, Cruise Control, GT94857286, Switch, Cruise ReleaseELECTRICAL, HORN88970419, Horn94857229, Relay, Horn94857231, Stock Horn Mounting BoltELECTRICAL, IGNITION88970216, Ignition Coil, 2ZZ Engines88970217, Sensor, Crank Angle, 2ZZ Engines94859442, Ignition Coil, 1ZZ Engines94859444, Sensor, Crank Angle, 1ZZ EnginesELECTRICAL, MISCELLANEOUS88972396, Engine Fuse Block CoverELECTRICAL, STARTER88969483, Starter Assembly94854542, Relay, StarterENGINE/TRANS, 1ZZ88971575, Heat Shield, 1ZZ Engines94859510, Retainer Clips, Engine Heat ShieldENGINE/TRANS, 2ZZENTERTAINMENT SYSTEMS88973324, Subwoofer - 2005+EXHAUST, BASE, GT MODEL88969624, Manifold, Exhaust, GT88969126, Pipe & Converter, Exhaust, Base88969127, Pipe & Converter, Exhaust, GTEXHAUST, AWD MODEL88971578, Manifold, Exhaust, AWD88969129, Pipe & Converter, Exhaust, AWDFLOOR94858267, Carpet Retainer, Trans TunnelFRONT BUMPER88969810, Front License Plate Bracket88969813, Front End Impact Bar88969815, Emblem, Pontiac Crest88970433, Upper Front Bumper Cover Support, RH88970434, Upper Front Bumper Cover Support, LH88970437, Rubber Bumper Hood Stop88970439, Front End Impact Bar Bracket, RH88970440, Front End Impact Bar Bracket, LH88970441, Foam Impact Absorber88972146, Upper Front Bumper Cover88973186, Bumper Cover, Lower Front94858560, Retainer, Push In, Lower Front CoverFRONT DOOR, EXTERIOR TRIM88969791, Moulding, Front Door, Lower Side, RH88969792, Moulding, Front Door, Lower Side, LH88969817, Nameplate, "Vibe" (Adhesive)88969819, Nameplate, "Vibe GT" (Adhesive)88969940, Outside Power Mirror, RH88969941, Outside Power Mirror, LHFRONT DOOR, HARDWARE88969772, Weatherstrip Assembly, FRH88969773, Weatherstrip Assembly, FLHFRONT FENDER88969694, Fender - RH88969695, Fender - LH88969696, Fender Liner Assembly - RH88969697, Fender Liner Assembly - LH88969790, Retainer, Moulding - 10/Side88970762, Fender Liner Bracket - RH88970763, Fender Liner Bracket - LH88970767, Retainer, Push In, Fender Liner Bracket - 2/Side88970767, Retainer, Push In, Fender Liner - 5/Side88970768, Fender Sound Barrier - RH88970769, Fender Sound Barrier - LH88970770, Filler, Fender - RH88970771, Filler, Fender - LH88972194, Spacer, Wheel Opening Moulding88972303, Moulding, Front Wheel, RH88972304, Moulding, Front Wheel, LH88972305, Seal, Moulding, Gray - RH88972306, Seal, Moulding, Black - RH88972307, Seal, Moulding, Gray - LH88972308, Seal, Moulding, Black - LH94852067, Seal, Fender - 3/SideFRONT INNER STRUCTURE, FRONT88969689, Support Assy, Radiator88970715, Shield, Engine Splash, MT, Base - RH88970715, Shield, Engine Splash, MT, GT - RH88970716, Shield, Engine Splash, MT, Base - LH88970720, Shield, Engine Splash, MT, GT - LH88970727, Bracket, Upper Bumper - RH88970728, Bracket, Upper Bumper - LH88970729, Support, Headlamp Housing - RH88970730, Support, Headlamp Housing - LH88970732, Bracket, Upper Grille88970733, Bracket, Support - RH88970734, Bracket, Support - LH88970735, Reinf, Upper Panel - RH88970736, Reinf, Upper Panel - LH88970737, Bar Assy, Lower Tie88970738, Reinf, Outer Tie Bar - RH88970739, Reinf, Outer Tie Bar - LH88970740, Reinf, Frt Inr Tie Bar - RH88970741, Reinf, Frt Inr Tie Bar - LH88970742, Reinf, Rear Inr Tie Bar - RH88970743, Reinf, Rear Inr Tie Bar - LH88970744, Support, Hood Latch88970767, Retainer, Push-In - 7/Side88972195, Bar, Upper TieFRONT INNER STRUCTURE, SIDE88969691, Apron Assy - RH88969692, Apron Assy - LH88970751, Rail, Upper Outer - RH88970752, Rail, Upper Outer - LH88970753, Bracket, Rear Upper - RH88970754, Bracket, Rear Upper - LH88970755, Reinf, Inner Strut Housing - RH88970756, Reinf, Inner Strut Housing - LH88970757, Panel Assy, Front Apron - RH88970758, Panel Assy, Front Apron - LH88970759, Bracket, Front Upper - RH88970760, Bracket, Front Upper - LH88970761, Ext, Front Panel - LH88970767, Retainer, Push-In - 7/Side88970772, Seal, Fender - RH88970773, Seal, Fender - LH88970803, Reinf, Rail - RH88970804, Reinf, Rail - LH88970806, Reinf, Rear Side Rail - RH88970807, Reinf, Rear Side Rail - LH88970808, Rail, Front Inner Side - RH88970809, Rail, Front Inner Side - LH88970810, Rail, Outer Side - RH88970811, Rail, Outer Side - LH88970812, Ext, Inner Side Rail - RH88970813, Ext, Inner Side Rail - LH88970814, Bracket, Impact Bar - RH88970815, Bracket, Impact Bar - LH88970816, Rail, Rear Inner Side - RH88970817, Rail, Rear Inner Side - LH88970818, Ext, Outer Side Rail - RH88970819, Ext, Outer Side Rail - LH88972196, Reinf, Outer Strut Housing88972288, Rail Assy, Inner Side - RH88972289, Rail Assy, Inner Side - LH88972290, Bracket, Crossmember - RH88972291, Bracket, Crossmember - LHFRONT INNER STRUCTURE, SUB-FRAME88969078, Bolt, Trans Support, Rear (2)88970699, Support, Trans, GT88970700, Support, Trans, Base88970701, Support, Trans, AWD88970702, Bolt, Trans Support, Front (2)88970704, Crossmember, Front Suspension, Base/GT88970705, Crossmember, Front Suspension, AWD88970707, Bolt, Crossmember, Front (2)88970706, Bolt, Crossmember, Rear (2)88970710, Dampener, Suspension, Base/AWD88970726, Hook, Front Tow94859023, Bolt, Tow Hook (2)FRONT LAMPS 9428904, Parking Lamp/Signal Bulb 9441733, Fog Lamp Bulb/Socket88969942, Headlamp Assembly, Combo, RH88969943, Headlamp Assembly, Combo, LH88969944, Fog Lamp Assembly, RH88969945, Fog Lamp Assembly, LH88972181, Headlamp Rubber Bulb Retainer91171148, Headlamp Bulb94857194, Parking Light/Signal Bulb SocketFUEL TANK88969124, Insulator, Fuel Pump88969125, Filter, Fuel88970237, Sender, Fuel - Base, GT88970238, Sender, Fuel - AWD88970247, Tank, Fuel - Base, GT88970248, Tank, Fuel - AWD88970249, Pipe, Fuel Filler88970255, Fuel Tank Pressure Sensor (Sensor 031070)88970258, Cap Assembly, Filler88970259, Strap Assy, Fuel Tank, R - Base, GT88970260, Strap Assy, Fuel Tank, L - Base, GT88970261, Insulator, Strap, R - Base, GT88970262, Insulator, Strap, L - Base, GT88970262, Insulator, Strap, L/R - AWD88970263, Strap Assy, Fuel Tank, R - AWD88970264, Strap Assy, Fuel Tank, L - AWD88970266, Shield, Heat - Base, GT88970267, Shield, Heat - AWD88971534, Hose, Fuel Filler88971542, Shield, Filler Hose88971543, Shield, Filler Pipe88972523, Pump, Fuel94853921, Gasket, Filler Cap94856991, Housing, Fuel PumpGRILLES88969806, Upper Grille Insert, RH88969807, Upper Grille Insert, LH94853733, Retainer, Push In, Front Grilles88969808, Lower Grille Insert, RH88969809, Lower Grille Insert, LHHOOD88969690, Hood Panel88969831, Latch Assembly, Hood88969832, Handle, Hood Release Cable88969833, Cable, Latch Release88970745, Seal Assembly, Front Hood88970746, Hood Insulator88970747, Retainer Clip, Hood Insulator, Front Seal88970748, Prop Rod, Hood Support88970749, Prop Rod, Retainer Clip88970750, Prop Rod, Grommet88971412, Spring, Hood Latch, 35mm Length88971413, Spring, Hood Latch, 58mm Length88971414, Shield, Hood Latch88971416, Clip, Center, Hood Release Cable88971417, Clip, Rear, Hood Release Cable88972193, Bumper, Hood Adjust94843142, Clip, Front, Hood Release Cable94852020, Insulator, Rear Hood Hinge94852021, Insulator, Front Hood Hinge94857419, Hood Hinge Assembly, RH94857420, Hood Hinge Assembly, LHHVAC88970273, Filter, Evaporator Air88970274, Valve, Expansion88970275, Tube, Evaporator88970276, Motor, Blower88970277, Actuator, Inlet Valve88970278, Core, Heater88970279, Resistor, Blower Motor88970280, Core, Evaporator88970281, Harness, Resistor88970291, Bolt, Upper Cushion (R/L)88972198, Tube, Drain88972200, Seal, Evaporator Pipe88972202. Compressor Assembly88972204, Clutch, Compressor88972205, Valve, Pressure Release88972207, Condensor Assembly88972208, Switch, Pressure88972209, Hose, Compressor88972213, Bracket, Rear Hose88972214, Bracket, Front Hose88972216, Pipe, Evaporator88972218, Clip, Evaporator Pipe88972259, Module Assy, A/C & HeaterINSTRUMENT PANEL88970565, Blank Covers, Hatch Button Panel88970583, Switch, A/C Control88974092, Cover, 12V Outlet 2005+INSTRUMENT PANEL, RADIO94851531, Bolt, Attaches Stock Radio To Mounting Brackets94858270, Bolt, Mounts Radio Brackets To DashLIFTGATE, EXTERIOR TRIM10426379, Emblem, Pontiac Crest (Adhesive)88969818, Nameplate, "Vibe" (Adhesive)88969820, Nameplate, "Vibe GT" (Adhesive)88969821, Nameplate, "ALL WHEEL DRIVE" (Adhesive)LIFTGATE, GLASS & PARTS88969784, Liftglass Assembly88969851, Strut, Glass Support, RH88969852, Strut, Glass Support, LH88970949, Weatherstrip Assembly, Liftglass88971497, Retainer Clip, CHMSL CoverLIFTGATE, SHEET METAL88969763, Door Shell, Liftgate88969848, Strut, Liftgate Support, RH88969849, Strut, Liftgate Support, LH88970948, Weatherstrip Assembly, LiftgateREAR BUMPER88970429, Cover, Rear BumperREAR DOOR, EXTERIOR TRIM88969793, Moulding, Rear Door, RH88969794, Moulding, Rear Door, LHREAR DOOR, HARDWARE88969774, Weatherstrip Assembly, RRH88969775, Weatherstrip Assembly, RLHREAR FENDER88972309, Moulding, Rear Wheel, RH88972310, Moulding, Rear Wheel, LHROCKERS/PILLARS/FLOOR, EXTERIOR TRIM88969795, Moulding, Rocker, RH88969796, Moulding, Rocker, LH88973001, Rocker Extension, RH - 2004+88973002, Rocker Extension, LH - 2004+ROCKERS/PILLARS/FLOOR, INTERIOR TRIM88970317, Moulding, Front Door Opening, RH88970318, Moulding, Front Door Opening, LH88970319, Moulding, Rear Door Opening, RH88970320, Moulding, Rear Door Opening, LHROOF, INTERIOR TRIM88972900, Cloth Visor, RH - 200488972901, Cloth Visor, LH - 2004SEATS, REAR88970643, Fold Down Release KnobWHEELS9593883, Center Cap, 16"/17" Aluminum Wheels22676859, Wheel Cover, 16" Steel Wheel88969156, Jack88970108, Wheel, Steel88970109, Wheel, Alloy, 16x6.588970110, Wheel, Alloy, 17x788970111, Wheel, Spare88970299, Strap, Jack Storage88970724, Bolt, Spare Anchor88971024, Stem, Valve, Spare Wheel94843633, Valve Stem94850175, Handle, Jack94855294, Wrench, LugWINDSHIELD88972500, Retainer Clip, A-Pillar TrimWINDSHIELD, WIPER SYSTEM85214-01010, Insert, Wiper, LH85214-02140, Insert, Wiper, RH 88969924, Insert, Wiper, RH88969927, Insert, Wiper, LHMISCELLANEOUS88969657, Keyless Entry Remote88972631, Key, Ignition
GMJAP
Post by GMJAP »
Raging - thought I saw this on your list before, but it seems to have gone missing: (Radio/etc face plate)88970554 PANEL, UPPER CENTER TRIMEDIT Adding:88973138 MFAM (Multi Function Alarm Module)
mcgusto82
Post by mcgusto82 »
no parts for seats.
kontinuous
Re: Master Parts Listing (GMJAP)
Post by kontinuous »
I don't think these are in your list yet, disreaguard if they are:Having an 05 I wanted the power point in the center console, I purchased the cap and socket hoping for the wiring harness. I ended up just splicing into the existing plug forward of the break, BUT if someone wants to purchase the six inch long easy plug in harness the number is 88972134. It Retails for $80.00!!!!!!!!The indoor air filter number is 88970273. Thanks again for the list!
2004 Vibe AWD
2005 Vibe Manual, SOLD :(
Sputnik
Re: Master Parts Listing (kontinuous)
Post by Sputnik »
I'm not sure what its called (So maybe its on the above list), but whats the part number for the black piece that makes your gas door spring open? Ours fell out, and our dealer was supposed to order it (after telling us, no your gas door opens fine! - right if you have two people there to get gas). My warranty runs out next Saturday so I want to get the part by then.
GenVibe Global Moderator
Re: Master Parts Listing (Sputnik)
I believe this is what you want:SPRING, FUEL DOOR88970516LIST: USD $14.47
Sputnik
Post by Sputnik »
Thanks. I'm gonna call them today and say where f is my part!? Okay I probably won't say the "f" but I'll feel like it.
ArcsVibe
Post by ArcsVibe »
Quote, originally posted by Sputnik »Thanks. I'm gonna call them today and say where f is my part!? Okay I probably won't say the "f" but I'll feel like it.Just say it! Trust me you will feel MUCH better
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
Sputnik
Re: Master Parts Listing (ArcsVibe)
Post by Sputnik »
huh. Apparently my part has been sitting there waiting for me... nice of them to call and tell me! Not!
Altus
Post by Altus »
Two parts I noticed missing from the list:Note - Toyota part #'s85242-12090 Blade, Wiper, Rear $10.67 CDN90915-YZZA1 Filter, Oil, 1zz $6.95 CDN
nortsr
Post by nortsr »
Great list. Must of took quite awhile to get it together and post. Now all I have to do is print ot out!
Folks, this list is FAR from complete. I'm still a couple thousand part numbers short. I haven't had a chance to finish it yet...Certainly don't print it out, it's very much incomplete.
Photoshots
Post by Photoshots »
Is there a part number for the little tie downs that slide in the track in the cargo area? I have the treadeded female slides, but I need the studs.
PhotoshotsBedford Texas2004 Vibe, Salsa, MonochromeMoon & toon, XM, Side airbags.
Yay, how about we add the following:88970225 MU4 automatic transmission (for FWD Vibes)
gnnr
Post by gnnr »
What's the part number for the remote start dealer option?Carpeted floor mats?Sill plates?
GNNRCurrent ride = 04 GrandPrix GT2Looking = Vibe or Vue
CFD911
Post by CFD911 »
i didn't see a # for the housing that the tweeters sit in. are they out there and any idea how much?
PAGING RAGING: Update yo list! Window regulator, LF, with power windows: 88969903Door checks:LF: 88937010RF: 88937009
ramenboy...
Post by ramenboy... »
here's another onerear bumper clip. also called 'retainer'. attatches facia to bracket to bumper. listed in raging's parts list for the front bumpers94858560price: get this 10 freakin dollars. i'm not kidding.
de-badged o4 vibe
o2 triumph speed four
kevera
Post by kevera »
Heres another Raging,Updated88973246-rear door lower molding88973242-quater panel molding
el_roy1985
Post by el_roy1985 »
88972524, Shroud w/ Reservoir, FanThis is what is listed in the list at the top. Although I just called the dealership and they have two part numbersVin 8 is 88973495Vin L is 88973496I need the fan shroud/reservoir, but now that there are 3 different part numbers I don't know which one to get.
VivaVibe
Post by VivaVibe »
Touch up paint, Shadow # 12346651Please varify this. Do you have to get it from GM, or is the type sold at auto parts OK, and how do you match the color as their numbering is different? The closest thing I found there was a GM Pewter, is that it?
2004 Base Shadow MonotoneMoon-n-Tunes, Power Pkg16" Alloys, AT, ABS, Side Air-bagsPin-stripe, 30% Tint, Fat exhaust tipMy GenVibe Garage
VforVIBE
Re: Master Parts Listing (VivaVibe)
Post by VforVIBE »
Quote, originally posted by VivaVibe » The closest thing I found there was a GM Pewter, is that it?a little darker then silver, it's not moonstone.Anyone know how much for a front arrowhead?
VivaVibe: We have no way to cross-reference GM part numbers with aftermarket paint companies. I can bet, however, going with anyone other than GM will NOT give you the closest possible match. Get it from your dealer, it's less than 10 bucks for a bottle.VforVIBE: If you have a part number, go to http://www.partszoneonline.com, enter the part number, and you can get an estimated price for the arrowhead (not including shipping).
scottj3
Post by scottj3 »
Can anyone tell me the mfg part number for the actual fuel door, and probably the hinge as well for a 2004 Vibe? Ours rusted off.
WaveAction
Post by WaveAction »
junk yard would be your best bet..probably pick one up for $10
waveresponder
Post by waveresponder »
whats the part number for the old style factory crossrails?...anyone know where i can find them?..thank
RAIL ASSY, CROSS 88969754
waveresponder
Re: (ragingfish)
you dont know hoooow stressed ive become trying to locate these...lol..i cant thank you enought dude .....so gm parts direct sells them for $102.28 individually per rail...http://www.gmpartsdirect.com/results.cfm..and i also just stumbled upon this site only cuz you gave me that part number... http://www.trademotion.com/par...gid=22 but they sell em for $133.36 each individually? ....do these prices sound alright or what?..im going to drill holes in them to mount a mini lightbar....
WaveAction
anyone know the part number for the TRD shiftknob..not the one thats round..but the one that looks very similar to the vibes shift knob..also does anyone know if a G6 or even the Torrents radio would work in the vibes?? i love their radios so much better..it looks to be about the same size...but im wondering about the actual connectivity and if it'll read everything properly
Gonzo
Post by Gonzo »
Anyone have any idea what the part number is for the trim piece that houses the tweeters in the doors.
TheGeebs
Re: (Gonzo)
Post by TheGeebs »
This may be what you are looking for. Your picture shows the left corner coverFront Door\Interior Trim\Corner Cover\W/Speaker 03-07 *88970377 http://www.gmpartsdirect.com/catalog/
adrienne
Post by adrienne »
Hi. Can anyone please tell me the part number for the Vibe's rear view mirror? It's cracked and it won't pass the inspection and I have no clue what to buy.Thanks so much.Adriana
tribalman
Re: (adrienne)
Post by tribalman »
what's the item called or the number that's lining around the front passenger wheel and also goes under the engine bay too? i looked at the list and couldn't figure it out. thanks.
None. Vibe is gone.
Re: (tribalman)
Quote, originally posted by tribalman »what's the item called or the number that's lining around the front passenger wheel and also goes under the engine bay too? i looked at the list and couldn't figure it out. thanks.88969696, Fender Liner Assembly - RH
MaryK618
Post by MaryK618 »
hi! i am looking for replacement engine splash guards for my 2005 ponitac vibe. i did a search on the part #s and found 88970715, 88970716 and 88970720, can anyone tell me if those are the correct part numbers? and where i could possible find them?? thank you so much!
kevera
Re: (MaryK618)
Post by kevera »
Quote, originally posted by MaryK618 »hi! i am looking for replacement engine splash guards for my 2005 ponitac vibe. i did a search on the part #s and found 88970715, 88970716 and 88970720, can anyone tell me if those are the correct part numbers? and where i could possible find them?? thank you so much!The 88970716 is for a manual transmission.If you have an auto,then the other 2 numbers are correct,left and right side.Get them here,http://www.trademotion.com/par...13761
spiffy1001
Post by spiffy1001 »
I have a 2009 Pontiac Vibe without the luggage rack. Where the Luggage Rack would be bolted in three of the bolts are covered by a small black plastic clip. I did not notice until I got home that one was missing. Does anyone know the part number for this clip?
'09 Base with slight damage in the back.
Houston
Re: (spiffy1001)
Post by Houston »
Your dealer parts department can find the number. It's covered by warranty, too.
06pvibe
Post by 06pvibe »
Whoa, Fish!! I know this is an old thread, but really... GOOD WORK!!! I'm, surprised more posters here didn't/don't seem to recognize the work that must have gone into posting this information.I don't know how much of it is still valid, but thanks!! Thanks a lot for your effort, time and trouble!!
waveresponder
Re: Master Parts Listing (06pvibe)
i know thread revival but it is an important thread....anywayyyyssis there a part number for the two plastic knob covers that you work to get the front passenger seat to fold flat? (laptop/table mode) i took them off kind of carelessly to install seat covers and now they dont want to stay on so im thinking i need to get a set (left, right)also if anyones familiar with the two retainer plastic clips on the back of the front passenger seat plastic backing...I need to get replacements for those as well as they dont want to stay in anymore
waveresponder
Re: Master Parts Listing (waveresponder)
bump, these are the parts im going to need after being dumb with my passenger seat install, was too lazy to take pics of the parts and stumbled upon pics on an old threadim also going to need the two different plastic clips that are used to hold the rear of the back of the front passenger seat plastic table or whatever it is you call it lol
rAERRK
Post by rAERRK »
im looking for this grille piece here, but im not exactly sure which one it is
Wolfbyke
Re: (rAERRK)
Post by Wolfbyke »
http://www.partswebsite.com/gm...03017It's called the outer right grille. i'm not promoting that website, just knew of it cuz i have to replace the left side one.
silverbullet
Post by silverbullet »
does anyone know where i can find a new rubber driver window seal? mines some all crushed and mangled in the corner. and how do i do that? it looks like it goes all the down into the window channel. door panel off? thanks for any help. tried looking on here and googled it, no luck
JetBlackVibeGT
Post by JetBlackVibeGT »
Hey the front of my car was demolished by something that fell off a guys truck today... needless to say the driver of the truck failed to notice... I need to get a replacement bumper, but I cant find one. Its for the Sport Package Ground Effects Front Bumper. Can anyone point me in the right direction?
"The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in their government."
paulclassa
Re: Master Parts Listing (ColonelPanic)
Post by paulclassa »
housing for tweeters part # ? did you find out im interested
DressedInBlack
Re: Master Parts Listing (paulclassa)
Post by DressedInBlack »
GM part no. 88970767Toyota part no. 90467-10183===============================================GM part no. 94858299Toyota part no. 90467-10161I have found both cheaper through Toyota.
http://
blackphoenix
Post by blackphoenix »
I have an 09 GT and i need a replacement driver's side rear tail lamp assembly, OEM. Where could I get one for a good price and what is the part number?
"Just because you could, doesn't mean you should."__________________________________________________________________BRING BACK PONTIAC!!!1993 Bonneville SSE (RIP)1999 Montana (RIP)2001 Grand Am GT (traded in)2009 Vibe AWD (RIP)2010 Vibe GT
paulclassa
There is only one listing ? I have a 2004 & I bought a 2005 engine & tranny & the tranny didn't have a electrical plug in for my wires it had a cover & bolt it's on the rear of tranny windshield side they junk yard doesn't give refunds so now I'm in the market for a 2005 vibe so I can one day use this part
