Standard Equipment
chillidog
Standard Equipment
Post by chillidog »
I recently picked up my Vibe. 1. The car had a Delphi battery in it, not an AC Delco as it should. Are these the same? 2. What is the model name of the standard issue tires on the base model? I hope I got what I was supposed to get.
NSimkins
Global Moderator
Re: Standard Equipment (chillidog)
Post by NSimkins »
quote:1. The car had a Delphi battery in it, not an AC Delco as it should. Are these the same?It may be hard to tell if all battery brands in the Vibe are the same from the factory. I don't have readily access to mine or I would look, but I assume Delphi or AC Delco are all acceptable. There could be different brands of batteries they purchase during the year so some could have AC Delco, Delphi, etc...quote:2. What is the model name of the standard issue tires on the base model?On the Base Vibe, you are either going to get Continental or Goodyear tires with the 16" rims.Check out this link for specifics: http://forums.genvibe.com/zerothread?id=954
NovaResource
Post by NovaResource »
quote:I recently picked up my Vibe. 1. The car had a Delphi battery in it, not an AC Delco as it should. Are these the same?I don't know all the details but Delphi is part of GM and makes AC Delco batteries among other electronic equipment. Basically they are one in the same.http://www.ipan.com/clients/Delphi/cpda ... s_main.htm
yank dini
Re: Standard Equipment (NovaResource)
Post by yank dini »
I'm gonna rip out my Delphi Battery in a few weeks, and buy a DIEHARD GOLD like I always do. I have been meaning to do this earlier but due to previous circumstances. I have been putting it off. When I looked the engine over before buying it. I noticed that those batteries only have 330 cold crank amps. The Diehard has 990 cold crank amps. I'm gonna need that in the winter especially when I have over a 1000-watts of music all though the car. It only costs about $90 or so sightly higher if you drive a Daimler Chrysler car bulit after 1998. Well worth it
chillidog
Post by chillidog »
Thanks to all!!!
MA-VIBE-FAN
Post by MA-VIBE-FAN »
quote: but Delphi is part of GM Delphi hasen't been part of GM for a couple years.
yank dini
Re: Standard Equipment (MA-VIBE-FAN)
Post by yank dini »
quote: but Delphi is part of GM Delphi hasen't been part of GM for a couple years.I didn't not know that eitherMaybe I should ask when that happened. I work down the street from their world headquarters right off 1-75 and Crooks road in Troy Michigan
NovaResource
quote:Delphi hasen't been part of GM for a couple years.That's why I said at the very beginning of my statement:quote: don't know all the details...And if you had read the info on the site I posted a link to you would have seen:http://www.ipan.com/clients/Delphi/cpda ... te:Earlier known as the Automotive Component Group Worldwide (ACG Worldwide) of General Motors, its operations were restructured and unified into a single identity called Delphi Automotive Systems in February 1995.
MA-VIBE-FAN
Re: Standard Equipment (yank dini)
. Maybe I should ask when that happened. I work down the street from their world headquarters right off 1-75 and Crooks road in Troy Michigan[/QUOTE]May 28, 1999
