Catalytic Converters
blk182@n7
Post by blk182@n7 »
Has Any one replaced this without adding the entire catback Sys? What size would be the direct fit for the Vibe GT? I would like to add a high flow Catalytic Converter, to the flowmaster.http://www.ptuning.com/html/se...=2003
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
blk182@n7
Post by blk182@n7 »
no replies Hmmmmm
Re: Catalytic Converters (blk182@n7)
Might wanna e-mail ptuning, I bet they can find out the right size for you.
blk182@n7
Post by blk182@n7 »
I wasa goingto do that but got lazy, someone had to have modded but i guess not.
blk182@n7
Post by blk182@n7 »
thats what i might end up having to do. was just wandering if anyone took time to install one yet. I have a flowmaster cat back sys. what it is is replaced pipe with mandrell bent and muffler is a flowmaster 60, i like it and there was a noticable change from the 2zz it also runs a bit cooler to.
Smokin' Rubber
Re: (blk182@n7)
Post by Smokin' Rubber »
As far as I've heard no one has been able to fit the high flow cat because of some placement and piping issues with front suspension clearance on either the vibe or matrix stock. I had to get mine specially modified (the piping for the cat) from part of GReddy's Evo II for the celica.
