have moon and tunes and thinking about replacing head unit
FCser
Post by FCser »
i plan to put a sub in my vibe, i think i may also replace the stock head unit. i have the moon and tunes package, isnt there a 200 watt amp someplace? i wont loose any power if i replace the stock HU i assume? what are some good headunits that fit the vibe well?
russ257
Re: have moon and tunes and thinking about replacing head unit (FCser)
Post by russ257 »
you will need to install in in line modulator to depower the signal coming from the headunit otherwise you will be amplifying and amplified signal which basically means you will lose volume control and it will sound bad but it can be done
Jahntassa
Post by Jahntassa »
Almost any headunit will fit the Vibe. A lot of people have gone for Pioneers, Kenwoods, Sony's.. It really depends on the features you want.As for the M&T amplifier, the best method of dealing with that thus far seems to be bypassing it.
FCser
Re: (Jahntassa)
Post by FCser »
is the m&t amp built into the headunit?
AKLGT
Re: (FCser)
Post by AKLGT »
no. it's located under the passenger's seat
AKLGT1998 Subaru 2.5RS
cdFxer
Post by cdFxer »
As a M & ex-T owner, I would recomend buying a decent head unit and bypassing the M & T amp. You can get as much or more performance from a decent replacement HU.
FCser
Re: (cdFxer)
Post by FCser »
hmm hopefully the sound quality willl still be good, i was looking at some alpine head units im looking for one that plays mp3's also i saw some ok units around 250 - 350 range kinda spendy but eh
Jahntassa
Re: (FCser)
Post by Jahntassa »
Alpine is one of the more expensive units you can buy. Go for a Pioneer or a Panasonic, they'll be cheaper and the Pioneer will sound just as good.
