Vibe bolt pattern...
LocDog
Post by LocDog »
I'm lookin to order rims offline, and i was wonderin what the bolt pattern is.
-aBySS Monotone Vibe-Auto Everything (I wanted a manual)-Moons and Tunes-No Badges-No Lateral Bars-Sony CDX-M730 Head Unit-200w PPI Amp Powering a 12" MTX Sub-9 1/2'' Stainless Steel Trumpet Air Horn-Spare Bridgestone Blizzaks Mounted on the Cheapest Steel Rims Ever
NSimkins
Global Moderator
Re: Vibe bolt pattern... (LocDog)
Post by NSimkins »
Using Search, I found the following links:http://forums.genvibe.com/zerothread?id ... 46#6546How are these? If it isn't enough, I'm sure someone else can fill you in (I can't).
LocDog
Re: Vibe bolt pattern... (NSimkins)
Post by LocDog »
I'm not sure if "5 bolt" is a standard size.
NSimkins
Global Moderator
Post by NSimkins »
Okay, this should be it then. Went to tires.com and did a search for the Vibe. Looked up the key for their product information and got the bolt pattern of:5-100 or 5x100Means there are 5 lug holes, 100mm (4 inches) apart.This is the legend for their codes: http://www.discounttiredirect.com/wheel ... .htmlOther info: http://www.tirerack.com/wheels/tech/bol ... mScrounged up this post from Scott (NovaResource) about his new rims here. Confirms 5-100 pattern.
yank dini
Post by yank dini »
That is correct sirIt has the same bolt pattern with all other Pontiac and Dodge Cars (based on experience)The same rims on my Vibe also fits a Dodge Stratus
LocDog
Re: Vibe bolt pattern... (Salsa!)
Post by LocDog »
Hmm thaks, i was wondering cause i wanted to get these rims off ebay, except that they're 5-120
NSimkins
Global Moderator
Post by NSimkins »
quote:Hmm thaks, i was wondering cause i wanted to get these rims off ebay, except that they're 5-120Those are nice rims.. too bad most late model BMW's utilize the 5-120 pattern, as you said.
cohocarl
Post by cohocarl »
If I remember correclty, the offset on the stock wheels is 38mm (or 40, I'm not 100% sure)
