Custom retained power outlet...
Kevy Kev
Post by Kevy Kev »
..has anyone ever tried this sucessfully? http://forums.genvibe.com/zerothread?id=2761Any pics? Please help. thanx.
2003 "ABYSS" PONTIAC VIBE GT
Re: Custom retained power outlet... (Kevy Kev)
I did http://forums.genvibe.com/zerothread?id=6403 but didn't mess with power to the audio systems
faygolovinjuggalo
Re: Custom retained power outlet... (joatmon)
Post by faygolovinjuggalo »
Quote, originally posted by joatmon »I did http://forums.genvibe.com/zerothread?id=6403 but didn't mess with power to the audio systemsWhy you guys are crazy..... talk about a fire hazard.... ok here ya go.. I install alarms and remote starters for a living... relays have a purpose.... they will prevent to much amprage draw.... other wish you will burn up switches and all kind of stuff... just for an example... say you add a set of fog lamps... they pull so much power that with out a relay they burn up the power switch.... here is the easy solution to your problem... I have not done this yet but I will just for you guys this weekend... (i need too for my XBOX) chase back the power wire on your invertor. once you find it the rest is simple... cut the wire in half... the side that is hooked to the invertor run to a constant power wire. If you are unsure where one is check this website out. http://www.bulldogsecurity.com they have it listed in the wiring diagram section. just make sure you fuse it. i dont care if it already fused. fuse it again. as close as you can to were you make your connection. a fuse cost like 5 cents.... better than burning **** up.....
WHEN I SAY "STOMP"....YOU SAY "WOOP WOOP""STOMP"mmfcl
Jahntassa
Post by Jahntassa »
Yeah, we don't have a way to have that delay so the radio stays on till you open the door. Check Joatmon's thread for making the 12v outlets on all the time.Please don't follow the suggestion by Fay, reasons for this are in joatmon's thread. It would cause your battery to die constantly..
faygolovinjuggalo
Re: (Jahntassa)
no dont listen to you..... unless you wanna burn your car up..... you will still have the damn power switch on the dash..... turn it off their when you are done..... SO NOW YOU WONT ALWAYS HAVE A DEAD BATTERY WILL YOU.... UNLESS YOUR A DUMB (removed) AND NEVER TURN IT OFF....
Easy there buddy, no need for hostility!GROUP HUG!!!
AKLGT
Re: (faygolovinjuggalo)
Post by AKLGT »
hey, disagreeing with someone is fine, but we don't need to be calling anyone names. just make your points and leave it up to people to make their own decision. then they cannot blame you if they mess things up.
AKLGT1998 Subaru 2.5RS
faygolovinjuggalo
Re: (trdvibe)
sorry just made me mad... lol... i am over it now...
