Supposedly the 04 GT has a new emissions pump installed that may hinder CAI installation.Haven't seen under the hood of an 04 GT yet, so I can't help unfortunately.
Quote, originally posted by syclnjr »Just curious to see out of us who havea 2004 who has installed a CAI and if they have run into any problems thanksMikeI have a 2004 and I had no problem at all installing a CAI I dont have a GT but I dont think it would be much different.
ragingfish I did notice on mine that if you look uner the stock airbox towards the front where the stock tube runs for the stock airbox there is a air pump or what looks to be one under there and it looks like it will adhere any installation of a CAI. I am keeping my hopes up for Injen to produce. If anyof you have seen what I am talking about let me know what you think. thanks
Mike2004 Vibe GT Abyss two tone, M/T, power package and 17's.
I didn't do that because there is a wierd hose or something there where it looks like the CAI goes. I don't want to sink my $$$ into something that complicated. I didn't even know what the hose does until now.
Desi SegundoFlint, Michigan'04 All Silver Vibe GT (Valerie) w/ the Sport packageSony CDX-M850MP H/U, Infinity CS6000 components, Rockford Fosgate FFC65, driven by Alpine MRP-F240 and Alpine MRV-T707 rocking 2 10" Alumapro'shttp://www.classicappreciation.com
Well I have some pretty cool plans for a cold air intake and I will let you all know when I get it done until then I guess that some of us can hope that Injen will pruduce the one that they so called made. We shall see though.Later
I have a 04 GT and I was planning on buying the CAI for the Matrix 04 XRS that just came out from Injen.....if it fits the Matrix it'll fit mine right?
2004 Vibe GT, Neptune Two ToneGraphite Interior, Moon & TunesPower Package, 17" Rims, Exhaust Tip Mods Tinted (50% front window, 35% back & rear)Cosmo Alpha Omega 3 Child Seat & Booster SeatCustom Cargo Mat, DebadgedMagnaflow Cat-back Exhaust, Injen CAI
Roadpig I am not sure that is what I am trying to find out. I am thinking yes but before I spend 200 some I need to know that it is going to fit and work correctly on my ride. I know that the diff between the Vibe and the Matrix is that the fog light on the Vibe sometimes adheres getting the filter on correctly. I will post something on here if I find it.Later
A note on the problem I think you are running into::I know it's comparing apples to oranges, but on my jetta, I had this same problem with an air pump being in the way of a CAI.I fabricated my own CAI as their design is simple and raw materials are cheaper than what you can buy from a performance parts place. The VW cai design also requires the resolution of the air pump problem, as there is a secondary air injection pump located under the manifold that takes filtered air from the airbox, and forces it into the catalytic converter upon cold startup. This helps to flash-heat the cat and reduce cold start emissions. The thing sounds like a jet engine - it's a very distinct noise. But anyway, I installed my CAI as I pleased, and then took a look at that hose. I removed the flexible hose that went to the airbox, exposing a hard piece of pipe that it was clamped to on the other end (opposide the airbox). The OD of this just happened to be the ID of a small breather filter that K&N makes. It's about 2" in diameter and fit there with no problems, secured with a hose clamp. The small filter keeps the air pump's air clean, and the CAI performs its duties without any complicated hookup arrangements. Just a thought - if your air pump function is anything like mine, this fix should work.
Hey wylde thanks for the reply and to be honest with you that is what I was thinking about on mine as I don't know all the specifics that go into the CAI design yet. I think that I am going to get a Cosmo intake and modify it as i please. Since shoot it is 108 bucks at the most and I can tinker with it to make it better. I am going to see about making something for the Cold Air Intake system to make things a bit easier for everyone but we will see how I get it all to work. I wil let everyone know when I do though. LaterAnd thanks again
