Wheel off set.
OutLaW
Wheel off set.
Post by OutLaW »
I was wondering what is the biggest off set you can go on a Vibe? I'm lookin at a set of wheels and they are +42mm offset. Just not sure the clearance on the strut. Don't wanna put down that much $ and have them not fit or even rub in the corners. Thank you. http://www.motegiracing.com/wh...desc=
MadBill
Re: Wheel off set. (OutLaW)
Post by MadBill »
You should have plenty of clearance on a 7" wide wheel with 42 mm offset, OutLaW. I have 10" wides with 38 mm offset, leaving the inner flange 34 mm or ~1-3/8" further inboard than yours would be.
OutLaW
Re: Wheel off set. (MadBill)
Post by OutLaW »
Ok, thanks for the info. LOL. I think I should have plenty of room. I'd measure all this stuff if I only HAD my car already! It'll be here in a couple of weeks. Ordered it 1 month and 1 week ago today. grrrr, takes too long!
Mavrik
Post by Mavrik »
my rims are a 45mm offset with no probs.
OutLaW
Re: Wheel off set. (Mavrik)
Post by OutLaW »
Hey, thanks for the info guys. Whats prolly the wides rims you'd be able to stuff under your car? I see you put 10" under yours. How far are you from the strut?
AKLGT
Post by AKLGT »
ya i saw some matrix wheels w/ 45 mm offset. sure you'll be fine.
AKLGT1998 Subaru 2.5RS
Mavrik
Re: Wheel off set. (trdvibe)
Post by Mavrik »
I'm not the only Viber with a 45mm offset cause I know someone else who has the same rims on their Vibe as I do. Of course I found out later after I bought mine. Guess someone else out there had great tastes.
MadBill
Post by MadBill »
Quote, originally posted by OutLaW »Hey, thanks for the info guys. Whats prolly the wides rims you'd be able to stuff under your car? I see you put 10" under yours. How far are you from the strut?Most people would say 8" is about as wide as you can go, but as mentioned, I shoe-horned in 10" with 275/40 x 17"s. They are 4-3/4" pattern Chev wheels that I already had, so I built adaptors which give a net offset of 38 mm. The clearance to the struts and inner fender wells is only ~3/8", but I've had no scuffing there. I did have to remove my Tein springs however. Especially on the front the combination of a 2"+ drop and seven sizes wider than stock tires was just too much! If I was starting from scratch, I'd likely go for maybe a 235 or 245 on an 8" wide wheel.
savedbyzero
Post by savedbyzero »
bigger the number the more the wheels are set in the wheel well...the smaller the more the will stick out. I'm probably gonna go with either a +35 or +38 to bring the wheels flush with body. The stock seem to be inset a little more than my liking.
THIS IS WHAT I DO...http://www.studiothisis.com
OutLaW
Re: Wheel off set. (savedbyzero)
Post by OutLaW »
Just got the call today.. My Vibe is in route to my dealer!!! Wooohooo!!
