VIBE GT What gas?
Helixthree
VIBE GT What gas?
Post by Helixthree »
Hey i had a question for all of you VIBE GT drivers...What kind of fuel do you run in your Vibe GT, is it Regular unldeaded (87), Plus (89) or do you run premium (91+)Also what does the manual say the fuel requirement is, and do you notice a difference running different levels of fuel.~Jason
In the road of life, there are passengers and drivers. I was always a VW driver... until i found my ride shedding its parts on the road... now i guess im just a driver in search of some new style that wont fall apart
Re: VIBE GT What gas? (Helixthree)
premium - 91try a search on "octane" to see some previous discussions on this topic, as well as http://forums.genvibe.com/zerothread?id=8440Not sure what the owners manual says, but you can download a softcopy of the owner's manual for free. See http://forums.genvibe.com/zerothread?id=1010GT will lose power on less gas, extended use of regular may lead to early engine wear, or worse
Helixthree
Re: VIBE GT What gas? (silverawd26)
Drag... ah well i guess you pay more for the fun ~Jason
Jahntassa
Post by Jahntassa »
Basically...I've been sticking to Amoco/BP 93 octane..which sadly is up to 1.77 here in the state of GA.
Psychobroker
Re: (Jahntassa)
Post by Psychobroker »
Quote »I've been sticking to Amoco/BP 93 octane..which sadly is up to 1.77 here in the state of GA.Consider yourself lucky. We Californians can only get as high as 91 at the pump (unless you fill up at a racetrack), and are now paying up to $2.25/gallon for it!
Reynoma
Re: (Psychobroker)
Post by Reynoma »
Here in NJ, I use either Mobil Super+ of Exxon Supreme (both 91 octane) for about $1.73 per gallon. I use Mobil and Exxon only because they are the closest stations and they contribute to Upromise. I get about 28 MPG on each tank (sometimes I can get 30). A fill up costs me anywhere between $15 to $17 depending on low my tank is (I usually try to fill up after I've gone about 250/275 miles).
Philippians 2:11
jackospades
Post by jackospades »
Stick to the higher octanes. I have noticed a difference between the mid-grade and the high-octane. Sluggish lift points it seemed to me.
Still running smooth....... in 6th gear.War Damn Eagle!!!!Go Tigers!!!!
johnsoax
Re: (Jahntassa)
Post by johnsoax »
Quote, originally posted by Jahntassa »Basically...I've been sticking to Amoco/BP 93 octane..which sadly is up to 1.77 here in the state of GA.Chicago 93 octane is up to $2.08 tonight.
Stang2Vibe
Re: VIBE GT What gas? (jackospades)
Post by Stang2Vibe »
I usually use 76's 93 octane. Sometimes I get 93 from BP/Amoco or Sunoco. Most Sunoco's around here even have 94 octane, though I don't really notice a difference between 93 and 94. One Sunoco station near me even has 110 octane racing fuel at the pump (I think it is leaded, though, so I won't be using that).From what I've read, it is important for GT owners to use 91 or higher octane due to the high revs and high compression, especially if you are revving into the "lift" range. The timing of the spark and burn of the fuel mix must be very precise when rpm's and compression are that high. Lower octane fuel may ignite prematurely (with the compression like a diesel engine) because it is less stabile than the higher octane fuel when compressed. Pre-ignition could cause some very serious engine damage to our cars. After reading about all that, I decided that I better not use lower octane fuel again.
AKLGT
Re: VIBE GT What gas? (Stang2Vibe)
Post by AKLGT »
best i can get right now is 90 octane for about 1.79/gallon
AKLGT1998 Subaru 2.5RS
FusionVGT
Post by FusionVGT »
Sonoco 94 is $2.00/Gal in Suburban Detroit
vibecrxsi240sxse
Post by vibecrxsi240sxse »
91 octane here in Houston, Tx. $1.65 87 octane is $1.50
Triton
Re: (vibecrxsi240sxse)
Post by Triton »
I either run 92 or 93 octane depending on what station I get it from. I may start going to BP/Amoco or Shell. For the most part I fill up every Tuesday. There is a station near me on the way to work that runs all three grades the same price as regular unleaded every Tuesday. You just have to be sure to get there around 6:30 a.m. or you will never get in there.
Jahntassa
Post by Jahntassa »
Triton: Sounds like a Texaco... up in Jersey, i'd -always- fill up at the local texaco station, and always time it for that "Super Tuesday", when premium was the same price as silver (usually 5-6 cents off)
hman33
Post by hman33 »
i run 93 octane which is about $1.90 in Oh.
'03 monotone lava gtpower package, moons and tunes,k & n short ram,grafxwerx overlays and inlay
VibeKid115
Re: VIBE GT What gas? (hman33)
Post by VibeKid115 »
I've heard that the useage of regular can cause detonation in the engine if used to much or as fast as one tank through it.
Re: VIBE GT What gas? (VibeKid115)
Hopefully the engine computer and knock sensor stuff will keep too much damage from a tank or two of regular, recurring use can't be good for the engine, and performance will suffer too. If you're going to pay for the extra kick of power the GT givs you when it hits lift, you shouldn't try to save money with cheap gas.Kid, welcome to genvibe!
MYKIDSGT
Re: VIBE GT What gas? (joatmon)
Post by MYKIDSGT »
I have noticed the mileage go down when I dont use premium.Over here : 76 prem 91oct $2.05gl last week, this week $2.25. It's what the pros use
MYKIDSGT VIBE GT ABYSS POWER/MOON & TUNES19" MILLE MIGLIA RIMS MICHELIN PILOT SPORT # 225/40ZRPics are Here http://members.cardomain.com/mykidsgt
DavidPIL
Post by DavidPIL »
Hi...I know most of you GT owners hate having to pay the additional cost of Premium fuel but there is a bright side to the price when it goes up. Let me explain...In most places, in the US at least, there is generally a 10 cent difference between grades... sometimes less but usually 10 between reg and mid and 10 between mid and prem. Let's say reg was $1.00 per gallon. If premium was $.20 more, you're paying 20% more, over the regular grade... As the price goes up, the percentage you pay over regular becomes less.... so reg @ $2.00 and prem @ $2.20, prem is only 10% more, not 20% as it was @ $1.20. I know, I'm thinking too much about it but it doesn't seem as bad when you really think about it...(I'll shut up now.)Dave
MadBill
Re: VIBE GT What gas? (DavidPIL)
Post by MadBill »
It makes me feel worse, David!North of the 49th, it's usually at least ten cents a litre (a tad over 1/4 gallon) more for Premium!
trocar
Re: VIBE GT What gas? (MadBill)
Post by trocar »
Put gas in today, regular was 73.9 cents/L and 84.1 /L for the 93 Octane.Cost $35 to fill it upAh well the joys of driving.
blk182@n7
Post by blk182@n7 »
has anyone put in 100 octane?
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
