Would these fit?!?
rcasciola
Would these fit?!?
Post by rcasciola »
im thinking bout rims and i was wondering if these would fit:4-5/100 4-5/114.3
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
Re: Would these fit?!? (rcasciola)
bolt pattern on the vibe is 5x100.5x114.3 would not fit.
rcasciola
Re: Would these fit?!? (ragingfish)
Post by rcasciola »
it has 5/100... thats the bolt pattern... so whats the 5/114.5 mean?!?
oh i get it, i thought you were asking about two separate wheels. my bad! not sure what that 5-114.3 is...
frostyGT
Post by frostyGT »
Quote, originally posted by rcasciola »4-5/100 4-5/114.3 What you have there are four different lug patterns: 4/100, 5/100. 4/114.3 and 5/114.3. I assume that you found a wheel and it said it was available in this size? They are just saying that you can order these wheels for any of those bolt patterns.Alot of wheels today are called Universal fit, as they have both 100 and 114.3 spaced lugs on the wheel. However, usually a wheel will be either 4 or 5 lug. And universal is really a misnomer, as there are 5-lug cars that don't fit a 5-lug universal size.Anyway...The Vibe is 5x100, so that is all you really need to know.Hope that answers your question
R.I.P. Frosty GTReplaced by 2006 Dodge Magnum R/T
rcasciola
Re: Would these fit?!? (frostyGT)
Post by rcasciola »
so then what is offset... and what if it doesnt say on the site?
you're missing the full wheel code.it should look something liek this:15x7 5-100 40can you paste a URL to the wheel you'r eintrested in? we might be able to help more with that...
frostyGT
Post by frostyGT »
Offset is the distance that the mounting surface of the wheel is from the exact centerline of the wheel.Positive offset means that the surface is on the "outside" of centerline, and negative means that it is on the "inside" of centerline (ie-deep dish wheels).I think you should be able to go to at least +42mm offset on the Vibe. Beyond that, I'm not sure. Anything less than +35mm offset is going to put added stress on the suspension setup. However, I believe you could go all the way to zero...ala gangsta style Like all those Geo Metros you used to see in the 90s!I recommend staying between 35 and 42.
rcasciola
Post by rcasciola »
http://www.cbwheels.com/mean617.htmthis is the direct site.. those r what im thinking bout getting.... take a look if ur interested.. it would help alot! Thanx
frostyGT
Post by frostyGT »
Pretty sweet looking wheels! The offset on that wheel is +42mm, so it should work fine. Two things to consider:1 - That polished lip will make the wheel look smaller.2 - If you're thinking of the white, it may not look too good with your two-tone Vibe. Of course, that is only my opinion...Otherwise, I think they look great!I just ordered some white ADR Tramas for my Vibe. I'll have them on this Friday and I'll post some pics.
Mavrik
Post by Mavrik »
The offset of the IKON rims for my Vibe is 45mm I know there are other Vibe members with the same and have had no problems that I know of but there wasn't any less offset to those rims.
Nervous_Dog
Post by Nervous_Dog »
I have 18" Tenzo-R Mean 6's in bronze. Mine are 5x100, I think the offset was +40 or +42. They'll look great on your Vibe. I get compliments on them all the time.
Nervous Dog2003 Monotone Lava GT w/ M&T and PowerMods: 18" Bronze Tenzo-R Mean Six rims w/ Kumho MX12" Rockford Fosgate Punch Sub in slot ported box2 - Rockford Fosgate Punch 201S amps2 pair - Rockford Fosgate P162C in front/rear doorsSony Xplod 5710 head unitHidden Hitch
rcasciola
Re: Would these fit?!? (Nervous_Dog)
Post by rcasciola »
can you please post a pic????
Nervous_Dog
Sorry, I don't have any pics of my car right now. But I can post a pic of the Sport Compact Car Project Matrix. It's red with bronze 6-spoke wheels on it. It looks so sweet I decided that was the look I wanted for my Lava Vibe GT.
drummerdude
Post by drummerdude »
Quote, originally posted by frostyGT »However, I believe you could go all the way to zero...ala gangsta style Like all those Geo Metros you used to see in the 90s!The 90's? I saw pimped out g-ride 2 days ago with that. They weren't ghetto, They were hispanic.
2006 MazdaSpeed6 GT which is for sale if anyone is interested...
