Installed new HDD - Need help.
kaybeejay
Post by kaybeejay »
I got an IBM/Hitachi 200 GB Drive as a second HDD for my computer. I plugged it in tonight and fired up the PC. The new drive shows up in the BIOS and Windows XP (Pro) was able to detect it, but it does not show up in explorer. I have a 60 GB IBM drive as my "master" on the Primary IDE cord, and a 200 GB IBM/Hitachi drive as the "slave" also on the primary IDE cord. There are no new drivers to install as far as I can tell. (tried to download already) Hardware installation wizard was no help. I am running Windows XP Pro from the 60 GB HDD ("master"). Can anyone help me?
2003 Shadow Vibe GT and 2001 Nissan Xterra 4x4
Charlievibe
Re: Installed new HDD - Need help. (kaybeejay)
Post by Charlievibe »
kaybeejay, did you get any error messages during your installation, or did it appear to be a completely clean installation? If you got error messages, do you remember what they were?Also, do you see it in My Computer?
Just because you see Charlie doesn't mean I am a he....sometimes Charlie can be a she!!!!
robdog
Post by robdog »
Well, on the new one, is the jumper set as a slave???
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
Is the new drive partitioned and formatted?you may have to go into control panel, administrative tools, computer management, storage, disk management, set up a partition on the new drive and then format it in order to put a logicial drive on the disk that windows can then start to use.
Charlievibe
Re: Installed new HDD - Need help. (joatmon)
Quote, originally posted by joatmon »Is the new drive partitioned and formatted?Exactly, joatman!!! Even if you think it is formatted, try reformatting it for your system.
kaybeejay
Post by kaybeejay »
No error messages at installation. The system started up normally and I got a little "new hardware" alert. That was it.The drive doesn't show up on "My Computer" either.The Jumpers are set to "slave".I pulled the drive right out of the box. Don't those things come pre-formatted? I guess it doesn't hurt to reformat it again - I will try it.
kaybeejay
Re: Installed new HDD - Need help. (Charlievibe)
Post by kaybeejay »
How about this? I asked this same question on another board and I got this reply:Quote »From Microsoft Knowledge Base:http://support.microsoft.com/d...97694New Drive or Mapped Network Drive Not Available in Windows ExplorerApplies ToThis article was previously published under Q297694 SYMPTOMSWhen you create a new volume on a local diskplug in a removable disk with existing volumesplug in a removable drive (for example, a USB floppy drive or PCMCIA flash card)add a physical hard disk or CD-ROM drive to your computeryou may experience any of the following symptoms: an existing mapped network drive is no longer available in Windows Explorerthe new drive is not available in Windows Explorerthe new drive appears in Windows Explorer, but when you open it the contents of the existing drive are displayedthe existing drive appears in Windows Explorer, but when you open it the contents of the new drive are displayedAfter your computer starts, the network drive may be replaced by the new drive.After you disconnect the new drive, the mapped network drive letter has the same logical drive letter that it had before you added the new drive.You may receive the following error message when you start your computer: The local device name is already in use.NOTE: The new device (or drive) may appear in Device Manager or the Disk Management console. CAUSEThis behavior occurs if you map a network drive to the first available drive letter after the drive letters for the local volumes and CD-ROM drives. When you install a new device or volume, Mount Manager, which assigns drive letters to volumes, does not recognize the mapped network drive and assigns the next available drive letter to the new device or volume. This causes a collision with the existing mapped network drive. WORKAROUNDTo prevent this issue from occurring, when you map a network drive, assign the highest available drive letter to the mapped network drive.To work around this issue if the new volume appears in Disk Management, specify a different drive letter for the new device or volume. To do this, follow these steps: Right-click My Computer, and then click Manage.Under Computer Management (Local), click Disk Management.In the list of drives in the right pane, right-click the new drive and then click Change Drive Letter and Path(s).Click Change, and in the drop-down box, select a drive letter for the new drive that is not assigned to a mapped network drive.Click OK, and then click OK again. Both the mapped network drives and the recently installed drive appear in Windows Explorer. STATUSMicrosoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article. MORE INFORMATIONBy default, Windows XP assigns mapped network drives to the highest available drive letter, starting with drive Z, to avoid drive letter collisions. However, by default, Windows 2000 assigns mapped network drives to the next available drive letter after the drive letters that are assigned to local volumes and CD-ROM drives. The information in this article applies to:Microsoft Windows 2000 ServerMicrosoft Windows 2000 Advanced ServerMicrosoft Windows 2000 Datacenter ServerMicrosoft Windows 2000 ProfessionalMicrosoft Windows XP Home EditionMicrosoft Windows XP ProfessionalMicrosoft Windows XP Media Center EditionMicrosoft Windows XP Tablet PC EditionLast Reviewed: 5/28/2003 (3.0) Keywords: kbenv kbHardware kbinfo kbnetwork KB297694
Charlievibe
If you bought the drive from someplace that says your drive is formatted for Win XP Pro, then you shouldn't need to reformat. I was looking for this information, and couldn't find it. I must be suffering from overload today. Anyhow, give the advice from Microsoft a shot, I think you will find it fixes your problem.
ShotInTheDark
Post by ShotInTheDark »
what type of motherboard do you have? I know of a lot of ppl that had that same problem with Asus motherboards. The bios does not except both drives set up that way for some reason. There is a current updated bios that helps.
cohocarl
Post by cohocarl »
Quote, originally posted by joatmon »Is the new drive partitioned and formatted?I've been running Win2K for quite some time, but know little about XP. Does XP use n.t.f.s.? If it does, and the new h.d. was formatted in fat32, they may not communicate. Just a guess.
kaybeejay
Re: Installed new HDD - Need help. (cohocarl)
Post by kaybeejay »
FYI. It works now.I partitioned and formatted the drive and now windows XP see's it.Albeit it only see's it as a 187 GB drive.
cohocarl
Post by cohocarl »
Quote, originally posted by kaybeejay »Albeit it only see's it as a 187 GB drive. Only?
Make sure you go into Start, Settings, Control Panel, Administrative Tools, Computer Management.In the tree on the left, click Disk Management.The disk you just installed will liked be Not Active. Right click on the RIGHT half of the drive (not where the name/letter are) and click Mark Partition as Active. If that is not an option, click Format first. Format it, then mark as active.Give that a shot!
Jahntassa
Post by Jahntassa »
Nono! That's right! A 200 Gb drive will ONLY format to 187 Gb! As you go up in drive size, you lose more available space for the formatting. It's just something that happens! This is why a 1.44 Mb High density floppy formats with 1.2 Mb of available space. I think there was a lawsuit about that a few months back, about how HD manufacturers need to state how much formatted space a drive has, not what the total space is..Also, no Harddrives come preformatted. You always need to partition them, especially with XP around, because not everyone would use NTFS or FAT32. Well..some drives might, but not the ones you'd pick up in the store..
