tired of waiting, so F it!
drunkenmaxx
Post by drunkenmaxx »
well, i figure there will never be a catback made for the awd, so i am going to eventually just get a magnaflow muffler. would someone reccomend which would be best for my AWD?(from ptuning) Also, am i correct in thinking i have to get the muffler welded on?
drunkenmaxx
Re: tired of waiting, so F it! (drunkenvibe)
ok, now, slow down, not everybody at once...
Quote, originally posted by drunkenvibe »ok, now, slow down, not everybody at once...Well, I would have told you but you're just too impatient. Maybe I'll tell you in a couple of days, if you learn your lesson.
drunkenmaxx
Re: tired of waiting, so F it! (joatmon)
ha! yeah... guess i'll just wait on one of the other of the hundreds of members!
shibaman
Post by shibaman »
Take your car to a good muffler shop and have them install a magnaflow and a nice stainless tip. It will make a difference!
Salsa basemoons and tunesInjen CAIHotchkis sway barsHotchkis springsCenterline RPM sMagnaflow muffler,stainless tipDevlop's custom STB
satur9
Re: tired of waiting, so F it! (shibaman)
Post by satur9 »
you can get it done cheap with muffler clamps you can get it done RIGHT with a good weld
Roadpig
Re: tired of waiting, so F it! (satur9)
Post by Roadpig »
for the AWD it's the catback for the 04 GT it's the CAI....I know where you are coming from!I will wait patiently.
2004 Vibe GT, Neptune Two ToneGraphite Interior, Moon & TunesPower Package, 17" Rims, Exhaust Tip Mods Tinted (50% front window, 35% back & rear)Cosmo Alpha Omega 3 Child Seat & Booster SeatCustom Cargo Mat, DebadgedMagnaflow Cat-back Exhaust, Injen CAI
drunkenmaxx
Re: tired of waiting, so F it! (Roadpig)
ok, here is what i really want to know. which of these would be the best to put on my awd? http://www.ptuning.com/html/se...=2003 anyone who responds; your input is appreciated!
MadBill
Post by MadBill »
Hi drunken.I'm assuming here that the AWD muffler is mounted crossways, the same as on the base and GT. If it runs parallel to the centerline on the left, ignore everything that follows. The problem with all of those "universal" mufflers is that they are designed to fit on a pipe running parallel to the centerline of the car. At 14" long for most, there isn't room on the left side for a crossover pipe from the right side to turn 90 degrees and connect. Also, the bumper mount flange hangs down quite far and the muffler might not clear. If you didn't mind carving up the plastic valence on the right side like I did with my duals [see pic (the cut's not as ugly as it looks here)], you could probably hook one up to the stock pipe just behind the axle and run it straight back on the right, but you'd likely be better off to find a muffler that had a 90 degree bend in the tailpipe(s) so it could fit crossways like the stock one.
rcasciola
Re: tired of waiting, so F it! (MadBill)
Post by rcasciola »
get a muffler!!! it makes a huge difference:)visit my car at:http://www.cardomain.com/id/rcasciolalet me know what u think;)
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
