Strange sound coming from front wheel
Sub-Vibe-R
Post by Sub-Vibe-R »
When I took my Vibe yesterday, I've heard a strange sound coming from the front wheel, driver side.It sound like 2 pieces of metal hitting each other. It sounds a little bit like you drive on a manhole and the cover is bented.It happend when I hit bumb or pothole, but not every time.I hope this has nothing to do with my Tien coil...I took a quick look and I did not notice anything wrong.Anyone has an idea what ca make this noise?
wicked1981
Re: Strange sound coming from front wheel (Sub-Vibe-R)
Post by wicked1981 »
Do you have a CAI? Mine use to make rattle noise because the filter was hitting the back of the fog light until I fixed it. If you dont have a CAI then not sure what it could be.
Sub-Vibe-R
Re: Strange sound coming from front wheel (wicked1981)
No CAI yet... and it seems to come from the back of the wheel. Sometime I have the feeling something hit under my feet...I did a visual inspection (without removing the whell) and I couldn't see anything wrong.... May be I'll have to jack the car and remove the wheel to see what cause this sound.... If I had a garage........
Sub-Vibe-R
I finally fopund from where was coming this sound...The top mont (sp?) strut bolt was loose. Few clic of ratchet and the noise is gone!!!By chance I found this before loosing the nut
Glad you found it. Do you think it came loose because of your springs mod, or is it something that you think we should all check?
Sub-Vibe-R
Re: Strange sound coming from front wheel (joatmon)
Quote, originally posted by joatmon »Glad you found it. Do you think it came loose because of your springs mod, or is it something that you think we should all check?It seems to be my fault. I haven't tighten it enough when I installed my spring... I leanr the hard way, but I could be worst.
Stang2Vibe
Post by Stang2Vibe »
I wonder if this is the popping noise that I hear sometimes coming from my front suspension? I have not changed any suspension parts yet, though. Everything is still stock. The sound you describe is similar to mine.
dmitri
Re: Strange sound coming from front wheel (Stang2Vibe)
Post by dmitri »
ahhh.. just saw this post. tomorrow morning imma check mine. I just created a new topic. I got the same exact noise on the front drivers side as well. I suspected it was the fronbt strut, but i visually didnt see anything loose...
Sub-Vibe-R
Quote, originally posted by Stang2Vibe »I wonder if this is the popping noise that I hear sometimes coming from my front suspension? I have not changed any suspension parts yet, though. Everything is still stock. The sound you describe is similar to mine.If all is stock on your car, bring it to the dealer.I didn't do it because I suspected the noise was cause by my coil install and I didn't wanted to pay the dealer to fix it.
Sub-Vibe-R
Re: Strange sound coming from front wheel (dmitri)
Quote, originally posted by dmitri »ahhh.. just saw this post. tomorrow morning imma check mine. I just created a new topic. I got the same exact noise on the front drivers side as well. I suspected it was the fronbt strut, but i visually didnt see anything loose...Nothing looks loose visually...At first, i removed the front wheel and take a look at all the bolts and nut. Everything was well tighten.Then I popped up the hood, removed the plastic cap from the top strut and i put my wrench on it...The bolt was kinda loose, give it about 1 full turn and tighten it properly. I did it 1 week ago and never heard the sound anymore.
dmitri
Post by dmitri »
ok ill look into it.
