Ka-poof!...Oh no!...and then...woosh woosh..
Faultline
Post by Faultline »
So I turned the corner onto Pearblossom hwy and mashed the throttle and boosted quickly toward 3rd gear with jolting torque, and lots of zoom...but I was a litttle sloppy and hit the rev limiter/fuel cut...at 6500 rpm...then my motor went..kapoof..".Oh no!." and then woosh woosh...!!!!..I just coasted w/ my foot off the throttle as I saw my cars life flash before my eyes in a mere few seconds!I thought I blew my motor!....but as I coasted...i reved my motor a little...it sounded ok!!!....I put it into gear...and then kept driving. All seemed well...I reved past 3k , and heard "woosh woosh"., but had no turbo power..and then I knew and drove home.The intercooler pipe bleww of my copressor housing!..When I popped the hood, I spotted it easilly...I hadn't checck the hose clamps ever, and now that i have 12k miles on this kit, I realized that I should have.....So, since the turbo was blowing freely into the air , I started to play with the throttle, to see how hard the air actually blows....Oh my gosh!...It is any wonder that engines dont blow up anyway...turbos are real copressors , and with a lot of cfm!....Ilooked around at all the leaves on my driveway..and thought about blowing then all off by hooking up the shop-vac hose to my turbo. ..Instead , I rehooked up my pipe , and tightened the hose clamp and drove to rite-aid to buy some celebration Ice cream...All was well!
Re: Ka-poof!...Oh no!...and then...woosh woosh.. (Faultline)
I can only imagine the empty gut deep feeling of dread you must have felt when you first heard the sounds. Imagine all the "I told you so's" you would have gotten if your turbo trashed the engine. Very glad it was a simple fix, and you're back to fast!
Faultline
Re: Ka-poof!...Oh no!...and then...woosh woosh.. (joatmon)
Post by Faultline »
Yeah , I dont like that tone of the "I told you so's" ..I have heard alot of the same tone pre-turbo pre-curser..."I dont know about that, you're gunna blah , blah blah.!"...And so ,it is true that if I ever blow my motor, that I will rebuild my motor w/ stronger rods, and pistons...then I will turn the boost up even more!...Its a pride thing...but the longer I go , the more confidence I gain...I have 12k miles and nearly one year....Matrix-t has over 30k miles on his matrix with the same set up..which makes the longevity thing even better![ Quote, originally posted by joatmon »I can only imagine the empty gut deep feeling of dread you must have felt when you first heard the sounds. Imagine all the "I told you so's" you would have gotten if your turbo trashed the engine. Very glad it was a simple fix, and you're back to fast!
satur9
Post by satur9 »
wonder why the fuel cut cause the pipe to blow off. did you backfire? i heard off the happening with boost increases or spikes creeps. seems a little odd what do you think nova?
Larry
Post by Larry »
I'm glad it turned out okay. That would've given me a good scar as well.
Faultline
Re: Ka-poof!...Oh no!...and then...woosh woosh.. (satur9)
Post by Faultline »
Quote, originally posted by satur9 »wonder why the fuel cut cause the pipe to blow off. did you backfire? i heard off the happening with boost increases or spikes creeps. seems a little odd what do you think nova?After thinking about it, I think that it may have been coincedental...I have done it before , and it acts like normal and just cuts off...one thing is for sure is that it was a nice cold 38 degrees out, and the trubo works reaaly well in the cold...so I am thinking that it probably would have popped off regardlass of the rev limiter..I dunno though.Oh yeah...I did not soud like a backfire..the sound was all under the hood..
Nervous_Dog
Post by Nervous_Dog »
Quote, originally posted by satur9 »wonder why the fuel cut cause the pipe to blow off. did you backfire?I'm thinking the pressure and the velocity caused the already loose pipe to blow off. I doubt it had anything to do with engine electronics.
Nervous Dog2003 Monotone Lava GT w/ M&T and PowerMods: 18" Bronze Tenzo-R Mean Six rims w/ Kumho MX12" Rockford Fosgate Punch Sub in slot ported box2 - Rockford Fosgate Punch 201S amps2 pair - Rockford Fosgate P162C in front/rear doorsSony Xplod 5710 head unitHidden Hitch
