I need to buy a new socket to take the lugnuts off our 04 Vibe. It has the 16" Alloy rims. Does anyone know what size these lugnuts are? IS there any issues with fitting a impact socket in the hole? It seems to hug the lugnuts awful close.Thanks,
Some wheels require a thin-wall socket to fit in the lug holes. Impact sockets tend to be a bit thicker and might not fit. Using a thin-wall socket on an impact gun usually breaks the socket when used for something with a higher torque spec.
Thanks for the information, maybe I need to restate it though. What size of a socket do I need to purchase to fit the lug nuts?I will keep an eye on the impact socket vs. regular...
Quote, originally posted by minivan »Does anyone know if the stock lugnuts are tapered?Do you mean tapered where the nut contacts the wheel? If so, yes they are so the wheel will center on the hub.
Quote, originally posted by minivan »The size was already mentioned above...12mm.Does anyone know if the stock lugnuts are tapered? I found out and thought I would post...I need a 21 mm socket to pull off the lug nuts.12 mm is the thread size...
For what it's worth, I just rotated my wife's tires and the lug nuts are the type that go down inside the rim. We have the 16" aluminum up-level rims...
