For any future or current Vibe owners or those who have not noticed this problem, here is a nice solution...If you notice on the rear hatch area where the license plate attaches, most Vibe's have 2 little pieces of foam stuck near the bottom of the plate area to prevent the plate from banging the hatch while in motion.While this does a great job, there is also the top plate area that comes in direct contact with the paint after it is screwed onto the vehicle. This direct contact can, over time, cause the paint to scratch off and/or wear away.A simple fix is to buy some little foam or soft-type one-sided adhesive pads that you can normally find at any hardware or parts store. The pads I bought were heavy-duty felt furniture pads that stick to the bottom of chairs so you can move them easily on the floor.Anything in this range of products will do the job depending on what you find. Wal-Mart or any other store will probably carry these.Here is a picture of the rear of the plate where I placed the pads to ensure that no part of the plate comes in direct contact with the paint:The package came with 4 pads and I ended up using them all. The plate does not stick way out from the vehicle as some may think. This type of modification to the plate is barely visible and will prevent damage to the paint underneath the plate.I have had these on for a month already and they have been subjected to water and hot/cold scenarios and are still adhered perfectly to the plate.
[Modified by NSimkins, 6:52 PM 9/2/2002]
