Just about to start swapping out my springs (I have the week off, yeah!). I'm using this Tien guide here as a guide:http://www.deepstaged.net/toymattein.htmDoes anyone know if you are supposed to cut the stops for the Eibachs? (Or any other Eibach specific tips?)
So far so good, got everything off and dropped it at the Firestone for the spring swaps. Removing everything took about 2 leasurely paced hours. Gonna put my progress rear sway on and paint my capilers while I wait.
Quote, originally posted by YoYo »Does anyone know if you are supposed to cut the stops for the Eibachs? (Or any other Eibach specific tips?) My last spring install was Eibach's and required no cutting with the bump stops.
Quote, originally posted by rasermon »My last spring install was Eibach's and required no cutting with the bump stops.You don't HAVE to cut the bumpstops, but while you have everything apart, why not do it on the off chance you end up hitting them all the time and then have to re-do the whole install...Pete (who has Eibachs with cut bumpstops)
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
