Autozone has two different ones. A coil and strut compressor,which would be the one to use?
Custom 3" CAI intakeBorla Exhaust,removed resonatorCustom ground kit Custom Ported ThrottlebodyOem 17" wheelsNAVagationComing soon Unorthodox underdrive and sportline springsIn that works (shortbelt mod) bypassing the the powerstering and A/C
quote:Autozone has two different ones. A coil and strut compressor,which would be the one to use?This is the coil spring compressor. Not to be used for removal strut/coil spring! This is the strut spring tool that you will use to compress the springs for removal on the vibe.
